ASA outside interface not pungable from multilayer switch
Mike_123
Frequent Visitor
Frequent Visitor
Hi can I get some help with this?  Ive tried GNS3 with ASAv and packet tracer for this lab and I cant seemt to ping the outside interface of my ASA from a multilayer switch with inside vlans. below are a list of things i configured
inside routes
static route to outside
default route to outside
access-list
all interface are up
Octavian Szolga
Level 9
Level 9
I don't think you're in the correct section of supportforums.
You can ping an ASA's interface only if you're coming from that side of the network;
meaning you can't ping outside if you're inside; you can ping in this case only the inside;
you can't ping the dmz interface IP if you're outside, and so on..
Octavian
