08-07-2014 05:12 AM - edited 03-11-2019 09:35 PM
I have Cisco ASA 5520 with VPN Plus license. I have to procure second unit and run it as Failover / Secondary unit.
what ASA part number should I buy so that I may have active / failover functionality with my above existing unit.
should i consider "ASA5520-BUN-K9" ?
08-08-2014 11:47 AM
Hi Zeshan,
Answer for your question.
Q.
Do I need to buy the same licenses for the secondary unit in a failover pair?
A.
No. Starting with Version 8.3(1), you do not have to have matching licenses on both units. Typically, you buy a license only for the primary unit; the secondary unit inherits the primary license when it becomes active. In the case where you also have a separate license on the secondary unit (for example, if you purchased matching licenses for pre-8.3 software), the licenses are combined into a running failover cluster license, up to the model limits.
Encryption license—Both units must have the same encryption license.
Karthik
08-10-2014 10:46 PM
Hi Karthik,
Thanks for your reply.
so it means that if i purchase "ASA5520-BUN-K9" with VPN plus license then i would be able to run my ASAs as primary / Secondary ( Active / Failovers ) units. I am talking about pre-8.3 software version. My ASA Software version is 7.2 and i also want to keep it same on new ASA unit because i am not comfortable with 8.3 or higher.
if above understanding is not correct then please let me know the model/part number details that i need to buy for my secondary ASA to run in active / failover senario.
08-10-2014 10:51 PM
HI Zeshan,
Yeah. Your understanding is correct... But as Marvin commented, that is an EOL/EOS announced model, you might not get the required new one via authorized channels.....
Pre-8.3 version - You should have the exact matching features/license on both devices....
Karthik
08-10-2014 11:03 PM
Thanks Karthik for explanation.
08-08-2014 06:59 PM
Karthik is correct in general.
However, the ASA 5520 is end of sales since Fall 2013. You will not be able to buy a new one via authorized Cisco channels.
