ASA problem - I cannot nat from hub router to outside interface
BC83676
I am having problems nating from DMVPN HUb router to outside interface.
Topology = (router -> outside switch -> ASA FW 9.x version)
I have been following the document https://www.cisco.com/c/dam/en/us/td/docs/solutions/CVD/Sep2017/CVD-IWANDeployment-SEP17.pdf however, i got stcuk on procedure 3 (Configure network address translation).
After configuration on asdm when trying to apply I have the following error:
[ok] object network dmz
object network dmz
[ok] host 192.168.1.1
[ERROR] nat stactic outside net-to-net
Address 172.168.1.1 overlaps with outside interface address.
ERROR: NAT Policy is not downloaded
Router can ping the Firewall, however it cannot ping internet (8.8.8.8).
Any
BC83676
After reviewing all the settings have concluded it was an ACL missing.
BC83676
