ASA problem
followurself
Level 5
Level 5
I want to configure a active/active failover using asa5520 and ips ssm module in it
wht i have tried but before that i will connecting the interfaces of these firewalls to a 3548 switch
wht i hv tried
asa1---g/0 goes to a 3548A switch
asa1---g0/3 is the stateful and failover link
asa1- g0/1 is connected to 3548B
asa1---g0/2 connected to 3548C
asa2--g/0 goes to 3548 switch
asa2- g0/3 is the stateful and failover link
asa2--g0/1 is connected to 3548B
asa2---g0/2 connected to 3548C
create 2 context OL and UA
the configuration is as such
asa1---
failover
failover lan unit primary
failover lan interface LAN-fo GigabitEthernet0/3
failover polltime unit 1 holdtime 5
failover link LAN-fo GigabitEthernet0/3
failover interface ip LAN-fo 172.16.1.117 255.255.255.252 standby 172.16.1.118
failover group 1
preempt
failover group 2
secondary
preempt
context OL
description Virtual Firewall For ONLINE APPS
allocate-interface GigabitEthernet0/0
allocate-interface GigabitEthernet0/1
allocate-interface Management0/0
config-url disk0:/ol.cfg
join-failover-group 2
context UA
description Virtual Firewall For UAT
allocate-interface GigabitEthernet0/2
config-url disk0:/ua .cfg
join-failover-group 1
asa2---
failover
failover lan unit secondary
failover group 1
preempt
failover group 2
secondary
preempt
as you can see g0/0 is shared ad connected to 3548 A switch, i must see 4 mac address on switch for the interfaces they connect
so asa1 --g0/0---3458 port4------3458 port 6-----g0/0----asa2
teh ip address on g0/0 of asa1 is
for context OL
ip address 192.168.18.135 255.255.255.0 standby 192.168.18.136
for UA
ip address 192.168.17.135 255.255.255.0 standby 192.168.17.136
the default gatewys are 192.168.18.1
now from the primary firewall going to context UA
i can ping the gateway 192.168.18.1
but when i go to OL
i cant ping 192.168.18.1
the 3548A switch maintains 4 macs..but sometime it losses the mac
icant understand why i cant ping from context OL its defalut gatewway
the problem doesnt come with interfaces g0/1 and g0/2 because they are not sahred.but i guess it the way its configured
Anybody
b.hsu
Level 11
Level 11
Try this:
To bootstrap the secondary unit in an Active/Active failover configuration,
perform the following steps:
Step 1 (PIX security appliance platform only) Enable LAN-based failover.
hostname(config)# failover lan enable
Step 2 Define the failover interface. Use the same settings as you used for
the primary unit.
a. Specify the interface to be used as the failover interface.
hostname(config)# failover lan interface if_name phy_if
