ASA Problem
Carmine De Rienzo
Frequent Visitor
Frequent Visitor
Hi at all,
I have the following problem:
The primary ASA  after some hours became unreachable on the Management interface and another interface while answer at ping on the others interfaces.
At same time for me it' s impossible to enter via ssh and telnet while before was possible it.
The Secondary ASA becames active and I can enter in it with ssh but If after some hours I have the same problem and then I have two firewall that don't work.
When I reboot both they became newly working.
Can suggest me which controls and troubleshooting I can do ?
I don't have crashinfo
The failover (when one only is working) shows the primary status failed but I m not able to know why ?
Let me know
Best Regards
Carmine
Jennifer Halim
What version of ASA are you running?
How was the CPU and memory of the ASA when it's not responding (you might need to console to check out the status).
Do you find anything in the logs that might tell you the reason?
Cisco Adaptive Security Appliance Software Version 9.0(1)
Device Manager Version 7.1(1)52 and cpu usage is 5%. In the logs I see only these errors:
FW-OPS-SUP(config)# sh logging asdm
6|Feb 24 2013 14:40:16|110002: Failed to locate egress interface for UDP from OUTSIDE:x.x.15.1/4445 to x.x.12.202/4445
6|Feb 24 2013 14:40:36|110002: Failed to locate egress interface for UDP from INSIDE:x.x.7.102/55196 to 1.1.1.1/53
6|Feb 24 2013 14:40:56|110002: Failed to locate egress interface for UDP from OUTSIDE:x.x.15.1/4444 to x.x.12.202/4444
3|Feb 24 2013 14:40:59|713902: IP = public address, Invalid packet detected!
3|Feb 24 2013 14:41:07|713902: IP = public address, Invalid packet detected!
3|Feb 24 2013 14:41:15|713902: IP = public address, Invalid packet detected!
The only debug that send me a error message is:
debug fover cable
fover event trace on
FW-OPS-SUP(config)# fover_health_monitoring_thread: fover_lan_check() Failover LAN Check
fover_health_monitoring_thread: fover_lan_check() Possible mate failure
debug fover cable fover_health_monitoring_thread: fover_lan_check() Failover LAN Check
ndebug fover cable odebug fover cable  debug fover cable fover_health_monitoring_thread: fover_lan_check() Failover LAN Check
FW-OPS-SUP(config)# sh failover
Failover On
Failover unit Secondary
Failover LAN Interface: FAILOVER Ethernet0/2 (up)
Unit Poll frequency 1 seconds, holdtime 15 seconds
Interface Poll frequency 5 seconds, holdtime 25 seconds
Interface Policy 1
Monitored Interfaces 5 of 110 maximum
failover replication http
Version: Ours 9.0(1), Mate 9.0(1)
Last Failover at: 13:05:10 UTC Feb 24 2013
    This host: Secondary - Active
        Active time: 7216 (sec)
        slot 0: ASA5510 hw/sw rev (2.0/9.0(1)) status (Up Sys)
          Interface OUTSIDE (x.x.s.5): Normal (Waiting)
          Interface VDDS (x.x.d.4): No Link (Waiting)
          Interface VIDEOSTREAMING (x.x.y.4): No Link (Waiting)
          Interface INSIDE (x.x.t.1): Normal (Waiting)
          Interface management (x.x.g.250): Normal (Waiting)
        slot 1: empty
    Other host: Primary - Failed
        Active time: 48300 (sec)
        slot 0: ASA5510 hw/sw rev (2.0/9.0(1)) status (Unknown/Unknown)
          Interface OUTSIDE (x.x.s.6): Unknown (Monitored)
          Interface VDDS (x.x.d.5): Unknown (Waiting)
          Interface VIDEOSTREAMING (x.x.y.5): Unknown (Waiting)
<--- More --->                        Interface INSIDE (x.x.t.2): Unknown (Monitored)
          Interface management (x.x.g.251): Unknown (Monitored)
        slot 1: empty
Stateful Failover Logical Update Statistics
    Link : FAILOVER Ethernet0/2 (up)
    Stateful Obj     xmit       xerr       rcv        rerr
    General        6418       0          31846      12080
    sys cmd      6418       0          6415       0
    up time      0          0          0          0
    RPC services      0          0          0          0
    TCP conn     0          0          464        0
    UDP conn     0          0          23449      28
    ARP tbl      0          0          1405       0
    Xlate_Timeout      0          0          0          0
    IPv6 ND tbl      0          0          0          0
    VPN IKEv1 SA     0          0          23         0
    VPN IKEv1 P2     0          0          89         0
    VPN IKEv2 SA     0          0          0          0
    VPN IKEv2 P2     0          0          0          0
    VPN CTCP upd     0          0          0          0
    VPN SDI upd     0          0          0          0
    VPN DHCP upd     0          0          0          0
    SIP Session     0          0          0          0
    Route Session     0          0          0          12052
    User-Identity     0          0          1          0
    CTS SGTNAME     0          0          0          0
    CTS PAC     0          0          0          0
    TrustSec-SXP     0          0          0          0
    IPv6 Route     0          0          0          0
    Logical Update Queue Information
              Cur     Max     Total
    Recv Q:     0     17     100765
    Xmit Q:     0     1     6418
Thanks a lot
Carmine
Hi Carmine
I have had severe problems with 9.0(1)...mainly regarding NAT though...but maybe its worth thinking about an upgrade to v9.1(1).
Ingo
