ASA stateful failover: connection nubmer between actice and standby are not same
fly
Level 2
Level 2
on active there are 17000 sessions
 but on standby only 8000 sessions?
  is this normal? i found some log and err on standby
ug 26 2015 15:12:51: %ASA-3-210005: LU allocate connection failed
Aug 26 2015 15:12:53: %ASA-3-210005: LU allocate connection failed
Aug 26 2015 15:12:54: %ASA-3-210005: LU allocate connection failed
Aug 26 2015 15:12:55: %ASA-3-210005: LU allocate connection failed
ASA5550-A# show failover
Failover On
Failover unit Primary
Failover LAN Interface: g0/2 GigabitEthernet0/2 (up)
Unit Poll frequency 1 seconds, holdtime 15 seconds
Interface Poll frequency 3 seconds, holdtime 15 seconds
Interface Policy 1
Monitored Interfaces 4 of 256 maximum
Version: Ours 8.2(5), Mate 8.2(5)
Last Failover at: 18:38:11 CN Aug 25 2015
        This host: Primary - Standby Ready
                Active time: 29269 (sec)
                slot 0: ASA5550 hw/sw rev (2.0/8.2(5)) status (Up Sys)
                  Interface outside (10.6.55.250): Normal
                  Interface outside-pi-1 (10.6.4.244): Normal
                  Interface outside-cn2 (10.6.3.38): Normal (Not-Monitored)
                  Interface inside (10.6.56.249): Normal
                  Interface management (0.0.0.0): Link Down (Not-Monitored)
                  Interface inside2 (10.6.59.253): Normal
                slot 1: ASA-SSM-4GE-INC hw/sw rev (1.0/1.0(0)10) status (Up)
        Other host: Secondary - Active
                Active time: 74354 (sec)
                  Interface outside (10.6.55.251): Normal
                  Interface outside-pi-1 (10.6.4.245): Normal
                  Interface outside-cn2 (10.6.3.37): Normal (Not-Monitored)
                  Interface inside (10.6.56.254): Normal
                  Interface management (192.168.1.1): Normal (Not-Monitored)
                  Interface inside2 (10.6.59.254): Normal
Stateful Failover Logical Update Statistics
        Link : g0/3 GigabitEthernet0/3 (up)
        Stateful Obj    xmit       xerr       rcv        rerr
        General         15803341   0          25818616   28332
        sys cmd         13813      0          13813      1
        up time         0          0          0          0
        RPC services    0          0          0          0
        TCP conn        12499770   0          18737420   8810
        UDP conn        3282047    0          7051875    19521
        ARP tbl         7711       0          15508      0
        Xlate_Timeout   0          0          0          0
        IPv6 ND tbl     0          0          0          0
        VPN IKE upd     0          0          0          0
        VPN IPSEC upd   0          0          0          0
        VPN CTCP upd    0          0          0          0
        VPN SDI upd     0          0          0          0
        VPN DHCP upd    0          0          0          0
        SIP Session     0          0          0          0
        Logical Update Queue Information
                        Cur     Max     Total
        Recv Q:         0       17      25996573
        Xmit Q:         0       1469    15834078
fly
Level 2
Level 2
do we have method to mannual re-synchronized connection table from active to standby
