ASA Static Routing same IP with different subnet masks
tselby3
Would having static routes on an ASA with the same IP but with a different subnet mask present any issues?
For example:
192.168.0.0/16
192.168.2.0/24
From what I understand it wouldn't present an issue because although they may have the same IP, the subnet mask places them on a different network.
TLS3
@tselby3 the /24 would be preferred when routing to the specific /24 network, else traffic to any other 192.168.0.0/16 network would go via the other next hop.
Example from my ASA, via same interface different next hop.
ASA(config)# show run route
route LAB 192.168.0.0 255.255.0.0 192.168.250.1 1
route LAB 192.168.10.0 255.255.255.0 192.168.250.2 1
ASA(config)# show route 192.168.10.0
Routing entry for 192.168.10.0 255.255.255.0
Known via "static", distance 1, metric 0
Routing Descriptor Blocks:
* 192.168.250.2, via LAB
Route metric is 0, traffic share count is 1
ASA(config)# show route 192.168.20.0
Routing entry for 192.168.0.0 255.255.0.0, supernet
* 192.168.250.1, via LAB
 Or different interface, different next hop.
route LAB 192.168.0.0 255.255.0.0 192.168.250.3 1
route VLAN7 192.168.12.0 255.255.255.0 192.168.7.2
ASA(config)# show route 192.168.12.0
Routing entry for 192.168.12.0 255.255.255.0
* 192.168.7.2, via VLAN7
ASA(config)# show route 192.168.0.0
* 192.168.250.3, via LAB
10 Replies 10
@tselby3 that will be fine, the route for 192.168.2.0/24 is more specific, so traffic will be routed via the configure next hop.
It issue'
If you have packet to 192.168.2.1 that need to route via 192.168.0.0/16 then asa will never forward it to correct interface' asa use longest match and hence always use 192.168.2.0/24
Try dont use overlapping subnet in any device
MHM
MHM
Sorry, not quite following what you are saying.  The static route entries would look like the below, they both would use a different interface and gateway.
Existing route:  Interface-A 192.168.0.0  255.255.0.0  x.x.x.x
New route:  Interface-B  192.168.2.0  255.255.255.0  y.y.y.y
TLS3
If asa need to forward traffic to host have IP 192.168.2.x and it connect via interface- A which static route asa will use?
Asa like ios devices use longest match and hence it will use static route 192.168.20/24 instead of 192.168.0.0/24 to forward packet to 192.168.2.x
This will make blackhole and packet drop.
So try avoiding use overlapping subnet as much as you can.
MHM
I see what you are referring to with a possibility of it having to go out interface-a.  I'll triple check, but I don't think 192.168.2.x on the /16 is used.  I do agree with you on not overlapping subnets on routes, but this is a network i inherited.
Rob
Thanks for your detailed replies.  I've got a few things to check before I enter the route and I'll go from there.
TLS3
tselby3
One more question, does the same apply if it is the same interface but different gateways?
Interface1  192.168.0.0  255.255.0.0  x.x.x.x
Interface1  192.168.2.0  255.255.255.0  y.y.y.y
TLS3
@tselby3 yes that will work, I updated the example above to reflect that scenario.
Sorry it not work.
Still asa see overlapping.
The asa will still prefer longest match and never try use 192.168.0.0 to forward traffic for 192.168.2.0.
MHM
