ASA Transparent Mode Using Management Interface
NotMeHere
Level 3
Level 3
The ASA configuration guide states that in transparent mode:
"The transparent security appliance uses an inside interface and an outside interface only. If your platform includes a dedicated management interface, you can also configure the management interface or subinterface for management traffic only."
Now when I configured the ASA as transparent I entered the following command to give it an IP addres in the global config:
ip address 192.168.1.250 255.255.255.0 standby 192.168.1.251
I also tried entering this command under the management interface, and the ASA just popped it back into the global config.
Should the ASA have 2 addresses? How do I give the ASA an address for management, in transparent mode, that it will answer to on the management interface? Sorry, but I must be missing something here and the configuration guide is a bit ambiguous on this.
thomas.chen
Level 11
Level 11
UNIQUE SECURITY MANAGEMENT INTERFACE DELIVERS CONSISTENT MANAGEMENT SERVICES
Cisco ASDM Version 5.0 delivers a single solution for all the configuration, management, and monitoring needs of the Cisco ASA 5500 Series Adaptive Security Appliances and the Cisco PIX Security Appliances. In addition to the rich configuration and management options available for best-of-breed security and VPN services, it provides a business-class solution to manage the truly adaptive security services provided by the Cisco ASA 5500 Series
http://www.cisco.com/en/US/products/ps6120/products_data_sheet09186a008014871d.html
