ASA vpn issue.. Please help
Rohit Mangotra
I have got an issue where SPOKE1 and SPOKE 2 cannot communicate with each other. However, SPOKE1 and SPOKE 2 can communicate with HUB. Please see configuration below for spoke and hub. I'll really appreciate if anyone could please guide me in right direction.
SPOKE 1  (Cisco SRST881, v. 12.4)
SPOKE 2  (Cisco 887VA, v.12.4(22r)
HUB          (ASA5525, v.8.6(1)2)
** Spoke 1 (Cisco SRST881, v. 12.4) **
crypto ikev2 proposal AES256-192-128-PROPOSAL
 encryption aes-cbc-256 aes-cbc-192 aes-cbc-128
 integrity sha1
 group 2
crypto ikev2 policy IKEv2-Policy
crypto ikev2 keyring VPN-KEYS
 peer ASA-DC
  address 200.200.200.1
  pre-shared-key local 12345678
  pre-shared-key remote 12345678
crypto ikev2 profile ASA-DC
 match identity remote address 200.200.200.1 255.255.255.255
 identity local address 50.50.50.1
 authentication local pre-share
 authentication remote pre-share
 keyring VPN-KEYS
crypto ipsec transform-set ESP-AES256-SHA esp-aes 256 esp-sha-hmac
crypto map SPOKE1-ASA 10 ipsec-isakmp
 set peer 200.200.200.1
 set transform-set ESP-AES256-SHA
 set ikev2-profile ASA-DC
 match address SPOKE1-VPN-ACL
interface FastEthernet4
 ip address dhcp
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface Vlan1
 ip address 192.168.210.225 255.255.255.224
 ip nat inside
ip nat inside source list NONAT interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 50.50.50.1
ip access-list extended NONAT
 deny   ip 192.168.210.64 0.0.0.31 172.16.0.0 0.0.255.255
 permit ip 192.168.210.64 0.0.0.31 any
ip access-list extended SPOKE1-VPN-ACL
 permit ip 192.168.210.224 0.0.0.31 172.16.0.0 0.0.255.255
 permit ip 192.168.210.224 0.0.0.31 192.168.210.64 0.0.0.31
** SPOKE2 (Cisco 887VA, v.12.4(22r) **
 integrity sha1
 group 2
 peer ASA-DC
 identity local address 100.100.100.1
 keyring VPN-KEYS
crypto map SPOKE2-ASA 10 ipsec-isakmp
 match address SPOKE2-VPN-ACL
interface Vlan1
 ip address 192.168.210.65 255.255.255.224
 ip helper-address 172.16.5.32
 ip nat inside
interface Dialer1
 ip address negotiated
 ip nat outside
 encapsulation ppp
 dialer pool 1
 ppp chap hostname zzz@zzz.com
 ppp chap password 7 zzzzzzzzz
ip nat inside source list NONAT interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip access-list extended SPOKE2-VPN-ACL
 permit ip 192.168.210.64 0.0.0.31 172.16.0.0 0.0.255.255
 permit ip 192.168.210.64 0.0.0.31 192.168.210.224 0.0.0.31
** HUB (ASA5525, v.8.6(1)2) **
object network SPOKE1
 subnet 192.168.210.224 255.255.255.224
object network SPOKE2
 subnet 192.168.210.64 255.255.255.224
object-group network INSIDE-SUBNET
 network-object 172.16.0.0 255.255.0.0
access-list VPN-SPOKE1 extended permit ip object-group INSIDE-SUBNET object SPOKE1
access-list VPN-SPOKE1 extended permit ip object SPOKE2 object SPOKE1
access-list VPN-SPOKE2 extended permit ip object-group INSIDE-SUBNET object SPOKE2
access-list VPN-SPOKE2 extended permit ip object SPOKE1 object SPOKE2
nat (inside,outside) source static inside-subnet-source INSIDE-SUBNET destination static SPOKE1 SPOKE1 no-proxy-arp route-lookup
nat (inside,outside) source static inside-subnet-source INSIDE-SUBNET destination static SPOKE2 SPOKE2 no-proxy-arp route-lookup
nat (any,outside) source static inside-subnet-source INSIDE-SUBNET destination static SPOKE1 SPOKE1 no-proxy-arp
nat (any,outside) source static inside-subnet-source INSIDE-SUBNET destination static SPOKE2 SPOKE2 no-proxy-arp
route outside 192.168.210.64 255.255.255.224 200.200.200.1 1
route outside 192.168.210.224 255.255.255.224 200.200.200.1 1
crypto ipsec ikev2 ipsec-proposal AES256-192-128-PROPOSAL
 protocol esp encryption aes-256 aes-192 aes
 protocol esp integrity sha-1
crypto map ASA-VPN-SITE 10 match address VPN-SPOKE1
crypto map ASA-VPN-SITE 10 set peer 50.50.50.1
crypto map ASA-VPN-SITE 20 set ikev2 ipsec-proposal AES256-192-128-PROPOSAL
crypto map ASA-VPN-SITE 20 match address VPN-SPOKE2
crypto map ASA-VPN-SITE 20 set peer 100.100.100.1
tunnel-group 50.50.50.1 type ipsec-l2l
tunnel-group 50.50.50.1 ipsec-attributes
 ikev2 remote-authentication pre-shared-key *****
 ikev2 local-authentication pre-shared-key *****
tunnel-group 100.100.100.1 type ipsec-l2l
tunnel-group 100.100.100.1 ipsec-attributes
same-security-traffic permit intra-interface
Thanks & Regards
Rohit Mangotra.
- See more at: https://supportforums.cisco.com/discussion/12535306/asa5525-v8612-spoke-1-2-not-communicating-each-other#sthash.ycTKQl6m.dpuf
8 Replies 8
After a quick look at the configuration of both spokes, I think you need to modify/add the nat access lists on both spokes as follows:
On Spoke 1:
  1 deny ip 192.168.210.224 0.0.0.31 192.168.210.64 0.0.0.31
  2 deny ip 192.168.210.224 0.0.0.31 172.16.0.0 0.0.255.255
  3 permit ip 192.168.210.224 0.0.0.31 any
On Spoke 2:
  1 deny ip 192.168.210.64 0.0.0.31 192.168.210.224 0.0.0.31
  2 deny ip 192.168.210.64 0.0.0.31 172.16.0.0 0.0.255.255
  3 permit ip 192.168.210.64 0.0.0.31 any
Aref
Hi Aref,
Thanks a lot for your reply. I tried the configuration you recommended but it did not work. Any other suggestions?
Thanks & Regards
Rohit.
You are welcome Rohit.
Please try to add the following:
nat (any,outside) source static SPOKE2 SPOKE2 destination static SPOKE1 SPOKE1
nat (any,outside) source static SPOKE1 SPOKE1 destination static SPOKE2 SPOKE2
May be they cannot reach each other because there was not nat exemption applied.
Aref
Hi Aref,
Thanks a lot for the reply. I tested the configuration, but it is still not working. I checked it by pinging from Spoke 1 to Spoke 2. Any other suggestions that you could please recommend.
Thank You,
Kind Regards
Rohit.
You're welcome.
Would you clarify what host is the 200.200.200.1? Also please share your topology with ip address scheme according to the above configuration for review.
Regards | Aref.
Hi Aref,
Please see the topology with ip addressing that you asked. Please let me know if you want me to change anything.
Thank You,
Kind Regards
Rohit Mangotra.
Hi Aref,
Any more thoughts regarding this issue.
Rohit
Thanks for all the help. The issue is resolved now. The problem was default NAT in ASA [nat (dmz,any) source static obj-192.168.1.0-nonatdmz obj-192.168.1.0-nonatdmz destination static obj-192.168.201.0-nonatdmz obj-192.168.201.0-nonatdmz no-proxy-arp].
so, we changed the ip address range [10.1.11.x/24, 10.1.12.x/24]of both spoke1 & Spoke 2. After the change its all working now.
Thank You
Kind Regards
Rohit
