ASA X-series firewalls difference & multi context features
will
Level 3
Level 3
Does anyone have a quick guide to show the feature differences between the X and regular ASA series firewalls?
And does this still hold true WRT multi-context ASA in the X-series?
No multi-context.....
- If you need to provide VPN services such as remote access or site-to-site VPN tunnels.
- If you need to use dynamic routing protocols. With multiple context mode, you can use only static routes.
- If you need to use QoS.
- If you need to support multicast routing.
- If you need to provide Threat Detection.
tia,
Will
Jennifer Halim
A few changes in the new ASA version 9.0 (supported on both ASA and ASA-X series):
http://www.cisco.com/en/US/docs/security/asa/asa90/release/notes/asarn90.html#wp586890
In multiple context mode, it does support the following:
- Site to site VPN tunnels only.
- Dynamic routing protocols: EIGRP and OSPFv2 only.
- QoS is not supported.
- Multicast routing is not supported.
- Thread Detection is not supported
Here is the unsupported feature on multiple context as off Version 9.0:
http://www.cisco.com/en/US/docs/security/asa/asa90/configuration/guide/ha_contexts.html#wp1382237
Jennifer Halim
thx much for the answer! the link was enlightening as well.
