ASA5510 slow speed
asfagan39
I have a Comcast 50/20 connection going into ASA5510 inside connections are getting speeds of 2/7. If I connect laptop on outside my speeds are 49/9 but inside speeds are really really low? How come? Anyone with or had this problem?
Pulkit Nagpal
Moving this discussion to Security community for quicker response.
Pulkit Nagpal
Community Manager- R&S
varrao
Level 10
Level 10
Hi Antoine,
Can you check if you have any error messages while accessing the internet on the firewall. You can check it by "show interface".
-Varun
Varun Rao
