ASA5515 9.4 port forward help
Johnni211
Hello I should reach our ftp servers in LAN from a public server. For example our public server 2.2.2.2, public interface of asa is 3.3.3.3. I set the following: Object NAT: object network obj_10.20.2.2 nat (inside,outside) static interface service tcp 21 2121 object network obj_10.20.2.3 nat (inside,outside) static interface service tcp 21 2122 My acls on the outside interface: access-list outside_access_in extended permit ip object myServer object ftp_server1 log notifications access-list outside_access_in extended permit ip object myServer object ftp_server2 log notifications access-list outside_access_in extended permit object ftp object Zabbix object log_server_zabbix access-list outside_access_in extended deny ip any any log warnings access-group outside_access_in in interface outside Objects: object network myServer host 2.2.2.2 object network ftp_server1 host 10.20.2.2 object network ftp_server2 host 10.20.2.3 But i can not reach the servers like this. The packet tracer said: asa5515# packet-tracer input outside tcp 2.2.2.2 1234 3.3.3.3 21 detail . . . Phase: 3 Type: ACCESS-LIST Subtype: Result: DROP Config: Implicit Rule Additional Information: Forward Flow based lookup yields rule: in id=0x7fffe1ad0d40, priority=0, domain=permit, deny=true hits=12461202, user_data=0xa, cs_id=0x0, use_real_addr, flags=0x1000, protocol=0 src ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=any dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=any, dscp=0x0 input_ifc=outside, output_ifc=any Result: input-interface: outside input-status: up input-line-status: up output-interface: NP Identity Ifc output-status: up output-line-status: up Action: drop Drop-reason: (acl-drop) Flow is denied by configured rule Any idea what should I do? Thank you in advance Johnni21
this one is wrong:
nat (any,outside) source dynamic NETWORK_OBJ_10.20.0.0_16 interface
replace it with the following to bring the rule to section 3:
nat (any,outside) after-auto source dynamic NETWORK_OBJ_10.20.0.0_16 interface
10 Replies 10
Your config looks good. But the packet-tracer-simutlation is wrong. You have to use:
packet-tracer input outside tcp 2.2.2.2 1234 3.3.3.3 2121
packet-tracer input outside tcp 2.2.2.2 1234 3.3.3.3 2122
Yes, you are right. I copied a wrong row. I used as you wrote.
So the config looks good. It is good, but i can not reach the server. Hmmm...
Thank you
And what is the (complete) result of the packet-tracer?
Phase: 1
Type: ROUTE-LOOKUP
Subtype: Resolve Egress Interface
Result: ALLOW
Config:
found next-hop 3.3.3.3 using egress ifc identity
Phase: 2
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
in id=0x7fffe138ef20, priority=0, domain=nat-per-session, deny=false
hits=101921769, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0, protocol=6
input_ifc=any, output_ifc=any
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Result:
input-status: up
output-status: up
Action: drop
Do you have a dynamic NAT statement in section 1? These statements should go to section 3. Can you share your complete NAT config?
nat (any,any) source static All-inside All-inside destination static All-inside All-inside no-proxy-arp
nat (inside,outside) source static NETWORK_OBJ_10.20.0.0_19 NETWORK_OBJ_10.20.0.0_19 destination static NETWORK_OBJ_172.16.0.0_22 NETWORK_OBJ_172.16.0.0_22 no-proxy-arp route-lookup
nat (inside,outside) source static NETWORK_OBJ_10.20.0.0_16 NETWORK_OBJ_10.20.0.0_16 destination static NETWORK_OBJ_10.20.253.0_24 NETWORK_OBJ_10.20.253.0_24 no-proxy-arp route-lookup
nat (inside,outside) source static NETWORK_OBJ_10.20.0.0_16 NETWORK_OBJ_10.20.0.0_16 destination static NETWORK_OBJ_10.20.252.0_24 NETWORK_OBJ_10.20.252.0_24 no-proxy-arp route-lookup
nat (inside,outside) source static NETWORK_OBJ_10.20.0.0_16 NETWORK_OBJ_10.20.0.0_16 destination static NETWORK_OBJ_10.20.251.0_24 NETWORK_OBJ_10.20.251.0_24 no-proxy-arp route-lookup
nat (inside,outside) source static any any destination static NETWORK_OBJ_10.20.252.0_24 NETWORK_OBJ_10.20.252.0_24 no-proxy-arp route-lookup
nat (inside,outside) source static any any destination static NETWORK_OBJ_10.20.253.0_24 NETWORK_OBJ_10.20.253.0_24 no-proxy-arp route-lookup
nat (inside,outside) source static NETWORK_OBJ_10.20.2.0_24 NETWORK_OBJ_10.20.2.0_24 destination static DM_INLINE_NETWORK_2 DM_INLINE_NETWORK_2 no-proxy-arp route-lookup
nat (inside,outside) source static NETWORK_OBJ_10.20.2.0_24 NETWORK_OBJ_10.20.2.0_24 destination static r1_subnet1 r1_subnet1 no-proxy-arp route-lookup
nat (inside,outside) source static NETWORK_OBJ_10.20.2.0_24 NETWORK_OBJ_10.20.2.0_24 destination static r1_subnets r1_subnets no-proxy-arp route-lookup
nat (inside,outside) source static NETWORK_OBJ_10.20.2.31 NETWORK_OBJ_10.20.2.31 destination static r1_subnets r1_subnets no-proxy-arp
nat (inside,outside) source static any any destination static NETWORK_OBJ_10.20.250.0_24 NETWORK_OBJ_10.20.250.0_24 no-proxy-arp route-lookup
this one is wrong:
I think you are right.
Can i replace it without anybody notice it in the network?
Thank you
If you first add the new line and then remove the old one, no user should notice it. But configurations like these should always be done at times of low network activity.
Dear Karsten,
The after-auto solved the problem. Thank you very very much!!!
