ASAv not pingable in GNS3
Starry M
I have created a basic scenario on GNS3 with ASAv and a PC but there I am troubling in ping issue from PC to ASAv or vice-versa. I am attaching ASAv configuration
hostname ciscoasa
enable password $sha512$5000$weTQEksgaEbyw8U3MT2a9A==$kzi7RjydjZXEtZO6bl55UA== pbkdf2
names
interface GigabitEthernet0/0
nameif inside
security-level 0
ip address 192.168.1.2 255.255.255.0
interface GigabitEthernet0/1
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/4
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/5
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/6
shutdown
no nameif
no security-level
no ip address
interface Management0/0
management-only
shutdown
no nameif
no security-level
no ip address
ftp mode passive
pager lines 23
mtu inside 1500
no failover
no monitor-interface service-module
icmp unreachable rate-limit 1 burst-size 1
icmp permit any inside
icmp permit any echo inside
icmp permit any echo-reply inside
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
arp rate-limit 8192
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 sctp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
timeout conn-holddown 0:00:15
timeout igp stale-route 0:01:10
user-identity default-domain LOCAL
aaa authentication login-history
no snmp-server location
no snmp-server contact
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpoint _SmartCallHome_ServerCA
no validation-usage
crl configure
crypto ca trustpool policy
crypto ca certificate chain _SmartCallHome_ServerCA
certificate ca 18dad19e267de8bb4a2158cdcc6b3b4a
quit
telnet timeout 5
ssh stricthostkeycheck
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
management-access inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
dynamic-access-policy-record DfltAccessPolicy
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
no tcp-inspection
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
service-policy global_policy global
prompt hostname context
call-home
profile License
destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
destination transport-method http
Further, for troubleshooting I have tried to capute the packets and in that FCS is incorrect message is showing up.
Attaching the screen shots for your reference.
After so many efforts now got the solution on it.
and it was very surprising to me that after downgrading the GNS3 to version 1.4.6 all things are working fine.
Thanks.
Saurabh
7 Replies 7
Maykol Rojas
I ran into a similar issue, but you are not going to believe what the solution is:
https://gns3.com/discussions/how-to-make-asav-interfaces-corr
Check that out and let me know.
Mike.
Mike
Hi Maykol,
Thanks for your response...
I have seen this but not getting understanding what needs to change in QEMU
setting, Please find attached screen shot for QEMU setting..please let me
know if anything needs to be changed in current settings.
Basically what it does state is that the Gig0/0 in the GUI is not the actual Gig 0/0 on the Firewall. The gig 0/0 is actually the management interface.
Right now, if you connect gig0/1 it will work, cuz the mapping  for gig0/1 on the GUI is the actual gig0/0 on the firewall you configured.
Mike.
Mike
Hi Maykol,
Again I tried the same thing what you have suggested but still having the
same issue.
Thanks.
Saurabh
Thank you  Maykol, it works。My GNS3 version is 2.2.35.1, ASAv version is 9.18(2)5.
I even could't believe that, is this probably GNS3's bug that the port  gig0/0 on ASAv in GNS'3 GUI is actually management0/0?
shuaiwuong
It's just because the dismatch of the interface' type - one's gigabitEthernet and another(the PC) is Ethernet.
