Block ICMP to FTD Device Interface IP in FDM
MxShay
Visitor
Hello everyone,
I have a small Firepower 1010 appliance without FMC. One requirement here is to block pings to the IPs of the device / its interfaces.
My research revealed that this setting can be set in the FMC via the platform settings using ICMP rules.
But since I only manage the appliance via the FDM, how can I block incoming pings directed to the firewall itself? Within the WebUI I did not find a corresponding setting, the same applies to the CLI.
Cheers and thanks!
Francesco Molino
At the bottom of the main dashboard on FDM, go to Advanced Configuration.
Create a Flexconfig Object like:
icmp deny any inside
and the following command on negate field:
no icmp deny any inside
It could also be:
icmp permit x.x.x.x 255.255.255.0 inside
and the following on negate field:
no icmp permit x.x.x.x 255.255.255.0 inside
Then attach this object on Flexconfig policy and deploy the config.
The platform setting ICMP configuration on FMC pushes this configuration directly to lina and let you avoid creating a manual flexconfig.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco Molino
It could also be:
Francesco
