CallHome Problem
aparmer0508
Community Member
I have setup a CallHome feature on a UCS through the GUI. I've followed it step by step in accordance to the instruction that I pulled from Cisco.com. However, I am not receiving the alerts or even when I click on the send inventory button. If I go in the UCS CLI, I can ping the SMTP server. So I know the SMTP information is correct. I did use the hostname for the SMTP and have configured the DNS IP address. I've added my email address on the Cisco TAC-1 profile. I've also created another profile and included my email address on it. But still no luck in receiving alerts. Can anyone assists with my problem?
Thank you in advance,
Alvin
Mark Elsen
 - You could, for instance, check the SMTP server's logs in order to determine, whether any SMTP-activity from the UCS server is seen.
M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Florin Barhala
Level 11
Level 11
I would also setup a capture on the firewall using as dst_IP the email server and port 25 and maybe SMTPs if the case.
Then wait and see what happens. Last but not least do you have proper connectivity from ASA to the SMTP server?
