Can i control the p2p grid system using Firepower?
kwon65211
Hi all
i'am using the FP 7000 Series.
internal user is having a problem because of the malicious p2p grid system.
Can i control the p2p grid system using Firepower?  (p2p grid name : winnetplus.exe)
I do not know Firepower supports this feature.
best and regards,
OSung
yogdhanu
Hi There,
I suppose you are trying to block p2p traffic through firepower. You can use application block option with access control rules to block "peer to peer" category in there and block it.
Hope it helps.
Yogesh
Hi there
unfortunately, this p2p application is not supported.
thanks your reply
OSung
Hi OSung
You can make a custom Application detector if you are up for the challenge. :)
http://www.cisco.com/c/en/us/td/docs/security/firepower/60/configuration/guide/fpmc-config-guide-v60/Application_Detection.html#ID-2208-00000060
