CBAC with NAT and H.323 problem
Thorsten997
Hi all,
There is Cisco 1921 router at the edge of the network performing NAT service with software (C1900-UNIVERSALK9-M), Version 15.0(1)M5, RELEASE SOFTWARE (fc2). Router is successfully performing NAT on IP packets, but IP address inside the payload (H.323 messages) remains unchanged (private). Because of that users on the inside network cannot establish video conferencing with remote users. VC is established normally among local users (because IP address both in IP header and in H.323 messages remains the same). How I can make NAT to change both address (in IP header and in H.323 messages) ? CBAC hasn't resolved my problem as well. I've done these things on router just to test CBAC:
      -Created extended access-list with permit ip any any
      -Applied it both to inside and outside interfaces of router
      -Created ip inspect rule:
           ip inspect name TEST h323
           ip inspect name TEST h323-annexe
           ip inspect name TEST h323-nxg          {Last two lines I've added just to use all possible inspection with H.323}
      -Applied inspection rule to inside interface in incoming direction. No success.
      -Applied inspection rule to outside interface in outgoing direction. No success.
So how I can use NAT in conjunction with CBAC (or which another solution I can use) to NAT address both in IP header and inside H.323 message to make video conferencing succeed? Thanks.
9 Replies 9
Julio Carvajal
CBAC restrictions regarding H.323:
H.323 V2 and RTSP protocol inspection supports only the following multimedia client-server applications: Cisco IP/TV, RealNetworks RealAudio G2 Player, Apple QuickTime 4.
Are you using one of those clients?
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Unfortunately we are using Polycom devices. Are there any other ways to make that work?
Hello Thorr,
In fact I think this should be working, is there a way you can post your config (with some changes due to security purposes)
Julio
Julio Carvajal
Julio,
There are the configs:
show access-lists
Extended IP access list 101
    10 permit ip any any (1964 matches)
show ip inspect all
Inspection Rule Configuration
Inspection name TEST
    h323 alert is on audit-trail is off timeout 3600
    h323-annexe alert is on audit-trail is off timeout 30
    h323-nxg alert is on audit-trail is off timeout 30
show running-config {some fragment}
interface GigabitEthernet0/0  {connects to provider}
ip address x.x.x.x x.x.x.x
ip access-group 101 in
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface GigabitEthernet0/1 {connects to inside network}
description connect to ASA outside
ip address Y.Y.Y.Y Y.Y.Y.Y
ip nat inside
ip inspect TEST in
duplex auto
speed auto
standby delay minimum 20 reload 20
standby 10 ip Z.Z.Z.Z
standby 10 priority 110
standby 10 preempt delay minimum 20 reload 20 sync 10
standby 10 name Redundancy
{NATing Polycom's local IP to global one:}
ip nat inside source static A.A.A.A V.V.V.V redundancy Redundancy mapping-id 1
ip nat inside source static B.B.B.B W.W.W.W redundancy Redundancy mapping-id 1
P.S.
There is Cisco ASA 5510 between router and internal switch. All ports (both in and out) are opened on ASA for Polycom devices.
Hello Thorr,
Are you doing inspection on the ASA for h323 and h323 ras??
Julio
Julio Carvajal
Julio,
No, I've turned off both h323 and h323 ras inspection on ASA. (The same result is achieved with inspection turned on on the ASA)
Hello Thorr,
ASA??? Isn't his a router running CBAC?
Julio Carvajal
Hi Julio,
No, ASA is between router and local network switch. As I'm doing NAT on border router I need addresses inside H.323 messages to be NATed too, so that's why I'm trying to use CBAC. (Some people states that CBAC in conjunction with NAT can translate addresses both in IP header and in H.323 messages)
Hello Thor,
That is correct, the embedded ip address should be translated, all you need is the H323 inspection
ip inspect xxxx h323
ip inspect xxxx h323callsigalt
Julio
Julio Carvajal
