05-17-2017 01:49 AM - edited 03-12-2019 06:23 AM
Hi All
I have attached an image of an error I am getting on ASDM, which is preventing me from managing/confuring the in built Firepower module on my Cisco ASA 5506X.
I have followed Cisco's step by step instructions like for like, however I still get this message. Does anyone have a solution or recommendation?
I am running the following software verisons:
Cisco ASA 5506
ASA Version: 9.6(1)
ASDM Version: 7.6(1)
Java: Version 8 Update 131
Cheers
James
05-17-2017 07:40 PM
I haven't seen that error before. What version of FirePOWER are you running?
Can you also share your Java Control Panel settings for security (both the Security tab and Advanced security settings)?
05-18-2017 12:14 AM
Hi Marvin
Please see attached file. It contains FirePower version and my Java settings.
I have IP connectivity between FirePOWER and the ASA so I know they can definitely see each other.
Do I require a later boot image for FirePOWER 6.0 or later?
When I show the dir on the ASA I have no boot image for firepower, might this be the issue?
James
05-18-2017 02:22 AM
Once the module has been bootstrapped, the boot image is no longer needed on the ASA flash disk.
Re Java, I was asking specifically about the following two screens. Please check them also.
05-18-2017 02:26 AM
My Java settings match yours displayed like for like.
Cheers
James
05-18-2017 03:26 AM
Hmm - that's odd. I've never seen it do that with ASDM.
Can you confirm that your "show module sfr detail" indicates all is well with the module?
If it's new, I would just go ahead and re-image with FirePOWER 6.2 and see if everything clears up after that.
05-19-2017 04:52 AM
The show module sfr detail shows all is well withg the module.
However now I get an error saying ASDM is unable to see the module, however when logged into ASDM I can ping the module and see it in the arp entries.
It seems extreamly painful to get this module working as I have the most up to date verisons of ASDM, Java, and ASA software.
I may need to raise a TAC case with Cisco for this as there seems no logic to why this isn't working
05-19-2017 05:03 AM
Yes - TAC is your best course at this point.
I have done a handful of ASDM-managed modules (and several dozen FMC-managed) but have never seen this partiucular issue.
