Cisco ASA 5505 ver 8.2.1 connection drops and loss of connections
loskene16
I just recently purchased a Cisco ASA 5505 ASA ver 8.2. I run a teamspeak server/ssh/dns and domain on the same server on the network. Before I switched to the asa, I have a regular DGL-4100 that ran with no issues. I have noticed that the connections are very unstable and disconnect frequently and when they do they take 1 to 5 minutes to be able to reconnect. I have done some cisco IOS but am fairly new to this.
Anyone know why this is happening? Below is my config off the device with ip's masked.
ASA Version 8.2(1)
hostname p-clvfsw1
domain-name XXXXXX.XX
enable password tFU encrypted
passwd encrypted
names
name 10.240.XXX.XXX P-CLVSRV1-125
name 10.240.XXX.XXX P-CLVSRV1-126
interface Vlan1
description to outside interface (CDE Lightband)
nameif outside
security-level 0
ip address dhcp setroute
interface Vlan2
description to inside VLAN
nameif inside
security-level 100
ip address 10.240.XXX.XXX 255.255.255.0
interface Ethernet0/0
description physical connection to CDE Gateway
interface Ethernet0/1
switchport access vlan 2
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
banner motd
banner motd +-+
banner motd | |
banner motd | *** Unauthorized Use or Access Prohibited *** |
banner motd | |
banner motd | For Authorized Official Use Only |
banner motd | You must have explicit permission to access or |
banner motd | configure this device. All activities performed |
banner motd | on this device may be logged, and violations of |
banner motd | this policy may result in disciplinary action, and |
banner motd | may be reported to law enforcement authorities. |
banner motd | |
banner motd | There is no right to privacy on this device. |
banner motd | |
banner motd +-+
banner motd
ftp mode passive
clock timezone CST -6
clock summer-time CDT recurring
dns domain-lookup outside
dns domain-lookup inside
dns server-group DefaultDNS
name-server P-CLVSRV1-125
name-server P-CLVSRV1-126
domain-name gsdomain.us
object-group icmp-type DefaultICMP
description Default ICMP Types permitted
icmp-object echo-reply
icmp-object unreachable
icmp-object time-exceeded
object-group service Teamspeak-UDP udp
port-object eq 9987
object-group service Teamspeak-TCP tcp
port-object eq 10011
port-object eq 30033
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
access-list acl_outside extended permit icmp any any object-group DefaultICMP
access-list acl_outside extended permit udp any interface outside object-group T
eamspeak-UDP
access-list acl_outside extended permit tcp any interface outside object-group T
eamspeak-TCP
access-list acl_outside extended permit object-group TCPUDP any interface outsid
e eq domain
access-list acl_outside extended permit tcp any interface outside eq ssh
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 10.240.XXX.XXX 255.255.255.0
static (inside,outside) udp interface 9987 P-CLVSRV1-126 9987 netmask 255.255.25
5.255
static (inside,outside) tcp interface 10011 P-CLVSRV1-126 10011 netmask 255.255.
255.255
static (inside,outside) tcp interface 30033 P-CLVSRV1-126 30033 netmask 255.255.
255.255
static (inside,outside) tcp interface domain P-CLVSRV1-125 domain netmask 255.25
5.255.255
static (inside,outside) udp interface domain P-CLVSRV1-125 domain netmask 255.25
5.255.255
static (inside,outside) tcp interface ssh P-CLVSRV1-125 ssh netmask 255.255.255.
255
access-group acl_outside in interface outside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa-server Remote_VPN protocol nt
aaa-server Remote_VPN (inside) host P-CLVSRV1-125
nt-auth-domain-controller 10.240.XXX.XXX
aaa-server Remote_VPN (inside) host 10.240.XXX.XXX
http server enable
http 10.240.XXX.XXX 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd dns P-CLVSRV1-125 P-CLVSRV1-126
dhcpd lease 691200
dhcpd ping_timeout 750
dhcpd domain gsdomain.us
dhcpd address 10.240.XXX.X-10.240.XXX.XXX inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 averag
e-rate 200
webvpn
tunnel-group DefaultRAGroup general-attributes
authentication-server-group Remote_VPN
authentication-server-group (inside) Remote_VPN
password-management
username-from-certificate CN
tunnel-group DefaultWEBVPNGroup general-attributes
password-management
class-map CONNS
match any
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
policy-map CONNS
class CONNS
set connection timeout tcp 2:00:00
service-policy global_policy global
service-policy CONNS interface outside
prompt hostname context
Shrikant Sundaresh
Hi Don,
One thing which seems odd:
class-map CONNS
     match any
policy-map CONNS
     class CONNS
Why match all traffic in all protocols, when tcp timeout needs to be set? Try disabling the CONNS policy for a while and check if that's causing delays.
Just do : no service-policy CONNS interface outside  for testing purposes.
Other issues with 5505, could be the fact that if you have a base license, then there is a restriction on number of allowed users. This would cause connections being denied due to reaching host limits. You can do "show version" to check this.
I would suggest setting up a syslog server, and collecting logs (if possible at level 6 or 7) during times when you see an increase in unstable connections or loss of connections. The logs would help determine what's going wrong.
Hope this helps.
-Shrikant
P.S.: Please mark the question as answered if it has been resolved. Do rate helpful posts. Thanks.
Thanks for your reply,
The class policy was put in because I read on the forums and they explained that putting in the class policy and setting a timeout in that fashion might correct the issue.However it didn't seem to help much. I did dig back thru to cisco logs and I am seeing TONS of teardown messages scrolling then stoping and starting up again. I notice the ip is a 65.55.7.141 which is a microsoft site. I see it scroll like 100 times incrementing up by 1 on the port. What would a denial because of max users look like?
I may have found it:
I ran a show tech-support and found 10 nic MAC's on it. I assume that each NIC is considered a user session, Am I correct?
Total NICs found: 10
Message #4 : 88E6095 rev 2 Gigabit Ethernet @ index 09Message #5 :  MAC: 0000.0003.0002
Message #6 : 88E6095 rev 2 Ethernet @ index 08Message #7 :  MAC: 6400.f139.430
Message #8 : 88E6095 rev 2 Ethernet @ index 07Message #9 :  MAC: 6400.f139.430
Message #10 : 88E6095 rev 2 Ethernet @ index 06Message #11 :  MAC: 6400.f139.430
Message #12 : 88E6095 rev 2 Ethernet @ index 05Message #13 :  MAC: 6400.f139.430
Message #14 : 88E6095 rev 2 Ethernet @ index 04Message #15 :  MAC: 6400.f139.430
Message #16 : 88E6095 rev 2 Ethernet @ index 03Message #17 :  MAC: 6400.f139.430
Message #18 : 88E6095 rev 2 Ethernet @ index 02Message #19 :  MAC: 6400.f139.430
Message #20 : 88E6095 rev 2 Ethernet @ index 01Message #21 :  MAC: 6400.f139.430
Message #22 : y88acs06 rev16 Gigabit Ethernet @ index 00 MAC: 6400.f139.430
Hi Don,
Run a "show version" on the  ASA, and look for the following output:
Licensed features for this platform:
Maximum Physical Interfaces : 8
VLANs                       : 3, DMZ Restricted
Inside Hosts                : 50
Failover                    : Disabled
VPN-DES                     : Enabled
VPN-3DES-AES                : Enabled
VPN Peers                   : 10
WebVPN Peers                : 2
Dual ISPs                   : Disabled
VLAN Trunk Ports            : 0
This platform has a Base license.
This will tell you the number of hosts allowed on the inside.
Could you please post some of the logs you saw. A tear down message is generally accompanied by the reason as well. Search for logs which contain the ip address of the server to which you are experiencing loss of/bad connections.
Hope this helps.
-Shrikant
Thanks again for the reply,
Here is the results from the show version command and I have attached a text file with the messages that were scrolling. HELP!!!
Cisco Adaptive Security Appliance Software Version 8.2(1)
Device Manager Version 6.2(1)
Compiled on Tue 05-May-09 22:45 by builders
System image file is "disk0:/asa821-k8.bin"
Config file at boot was "startup-config"
p-clvfsw1 up 20 hours 58 mins
Hardware:   ASA5505, 512 MB RAM, CPU Geode 500 MHz
Internal ATA Compact Flash, 128MB
BIOS Flash Firmware Hub @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-5505 on-board accelerator (revision 0x0)
                             Boot microcode   :  CN1000-MC-BOOT-2.00
                             SSL/IKE microcode:  CNLite-MC-SSLm-PLUS-2.03
                             IPSec microcode  :  CNlite-MC-IPSECm-MAIN-2.04
0: Int: Internal-Data0/0    : address is 6400.f139.430e, irq 11
1: Ext: Ethernet0/0         : address is 6400.f139.4306, irq 255
2: Ext: Ethernet0/1         : address is 6400.f139.4307, irq 255
3: Ext: Ethernet0/2         : address is 6400.f139.4308, irq 255
4: Ext: Ethernet0/3         : address is 6400.f139.4309, irq 255
5: Ext: Ethernet0/4         : address is 6400.f139.430a, irq 255
6: Ext: Ethernet0/5         : address is 6400.f139.430b, irq 255
7: Ext: Ethernet0/6         : address is 6400.f139.430c, irq 255
8: Ext: Ethernet0/7         : address is 6400.f139.430d, irq 255
9: Int: Internal-Data0/1    : address is 0000.0003.0002, irq 255
10: Int: Not used            : irq 255
11: Int: Not used            : irq 255
Inside Hosts                 : 10
Failover                     : Disabled
VPN-DES                      : Enabled
SSL VPN Peers                : 2
Total VPN Peers              : 10
Shared License               : Disabled
AnyConnect for Mobile        : Disabled
AnyConnect for Linksys phone : Disabled
AnyConnect Essentials        : Disabled
Advanced Endpoint Assessment : Disabled
UC Phone Proxy Sessions      : 2
Total UC Proxy Sessions      : 2
Botnet Traffic Filter        : Disabled
Serial Number: JMX15144029
Running Activation Key: 0x333cc36e 0xd441e9e8 0xcc80b968 0xbc8cfc98 0x8b0718be
Configuration register is 0x1
