Cisco ASA 5525 problem
psm9328
Frequent Visitor
Frequent Visitor
Hello Everyone,
I want to ask a quetion.
We have a Cisco ASA 5525.
The equipment has never been turned off but,
If it look at the operating hours of the equipment(device up time) in ASDM, it turned off and on a few days ago.
we already runed Cisco CLI analyzer tool, but nothing find.
Why it have these symptoms?
We need to find if it is possible that reason.
Is there any way to know why these symptoms appear?
Please let me know if there is a good way. I beg you
Thank You ,
8 Replies 8
balaji.bandi
show verion show you the updatime, if you do not have configured any syslog server, then you may not able to find the reason why it was reloaded ?
BB
Thank you for your answer.
Let me check.
Asa Show version command
Reload reason <-
As a result of checking, there is no reload reason.
Not only this equipment, but also other ASAs didn't have it. Do we need to set it up?
You will not see on ASA reload reason, as per i know, since there is no Logs stopred on device (you may not able to find that information)
until we look any more Logs we see in flash.
how long was the uptime before it rebooted ?
9.6.X code is quite old, may be uplift and observ.
Other note, what you see logs on the switch it connected this ASA , is the switch also rebooted ?
if you really more keen to understand the issue and have support Raise TAC Case.
BB
In effect, the equipment was not rebooted.
However, the equipment operating time was initialized in ASDM.
So I want to know why
johnlloyd_13
Level 11
Level 11
hi,
can you share a 'show crashinfo' output.
if there's no crashinfo output, i would suggest to use/transfer to more a stable power source or better use UPS.
I will share it with you when I extract the 'crashinfo'.
thank you
