Cisco Firepower Device Manager (FDM) Management over Site to Site VPN
Amoret
I have a Site to Site VPN setup from an ASA 5510 (ASA Code) to an ASA 1010 (Without FMC); we are using the FDM GUI to manage this. The Site to Site VPN is working fine!
I'm trying to open the HTTPS FDM GUI over the site-to-site VPN.
ASA5510 192.168.24.0/22
ASA1010 10.0.64.0/24
On the LAN of the 10.0.64.0/24 network, we can access the FDM GUI (10.0.64.1).
On the LAN of the 192.168.24.0/22 network, we can not access the FDM GUI (https://10.0.64.1), we also can't ping 10.0.64.1 over the site to site
9 Replies 9
Amoret
I created a FlexConfig Template - "management-access inside" and Negate Template "no management-access inside" and now I can ping the inside interface, that's 50% of what I am trying to do but I can not access the FDM GUI over the Site-To-Site VPN?
@Amoret did you change the management access to permit the connection from the source network?
@Amoret the inside interface is a data interface, that screenshot is of the management interface.
I'm starting to hate the FDM, the ASA was so much easier but I am forcing myself to learn this! Saying that are you referring to the "Data Interfaces"? If so I have tried adding it here. I added the 192.168.24.0 network to the inside and for kicks, I added it to the outside also.. still not working
@Amoretdid you deploy the policy? The orange dot indicates you need to deploy some changes.
Yes, it's deployed. I have added it and removed it a few times, I added it back for the screenshot then deployed it. I can ping the inside interface now but can not access https://10.0.64.1 over the site-to-site.
No more comments?
