Cisco FMC syslog problem
i am having a very unusual problem with the cisco FTD / FMC.
After updating a manual ip blacklist, the Cisco FMC is no longer sending the logs to my remote syslog...
I'm sure I haven't made any changes and checked the configuration.
Anyone have any ideas?
Do you think a reboot can fix something?
Update:
I understand that the Syslogd daemon doesn't work, and it doesn't even start on reboot.
   - Do you have any additional info's on that , such as errors observed from the 'local' logging ?
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
