Cisco FTD 6.6.5 - Process Status : Critical Snort Detection Engine
Agung1007
Hi Team,
Greetings to you all,
Recently (or on this week),
My customer FTD Device (Version 6.6.5, managed by FMCv 6.6.5) report that they have some issue
the symptoms is:
- on random time, the device drop all the connection (especially uplink to internet)
- already happened 3 times (on 24 March, 25 March & 28 March)
- the FMC suddenly logout when the issue happened (dont know if related or not)
- the downtime happened about 5-10 minute, then the device running normally again
already check all the status health for interface, platform, hardware , running normally
BUT
when I try to check all the module I found that the process Status (Critical) : The Primary Detection Engine process terminated unexpectedly 1 time(s)  (attached)
*the timestamp matches with the report that customer give when the downtime happened
Already check with the community and google:
- caused by SMB etc +
FN this issue
- after upgrade to 6.4.0.2
because of the SI URL Rule
-  Spero analysis on File Policy
- SNMP
which all telling me the same that it caused by Snort Detection Engine and happened on FTD/FMC version Below 6.6.5 (the issue should be solved right in the newer version like on 6.6.x ?)
Do you guys have some idea why it happened?
on how the workaround for this issue?
Many thanks!
Regards.
0 Replies 0
