cisco ips 4206 Analysis Engine not running
Anand Sharma
Community Member
Cisco IPS 4206
AnalysisEngine     BE-BEAU_E4_2010_MAR_25_02_09_7_0_2   (Ipsbuild)   2010-03-25T02:11:05-0500   NotRunning
Sensor health is showing critical .
Application showing failed .
Can any body help me on this,.
JonPBerbee
Level 3
Level 3
We have had this issue in the past with our sensors and the only way that we were able to clear it was with a reboot of the sensor.  If you decide to reboot then you should probably do a "show tech" before the reboot and open a case with support to see what the root cause of the issue was.
