CiscoView 5.3 problem
akoussan
hi,
I have CiscoWorks 2000 LMI1 , with CiscoView 5.3
In my 7206 VXR router there is two Escon Channel [ PA-4C-E] , in the default packages of the CiscoWorks 2000 LMI, this card is not supported , so I downloaded the Rtr7000.cv50.v13-0.zip ....
the problem is when I installed this patch I'm not able to see the VXR router at all , when I ask for a view of the router it gives me [Internal Error]
what I have to do? I cannot go back to the previous patch !!!
plz help
lisa.hall
Level 7
Level 7
Did you take a look at the Ciscoview FAQ. This has many useful tips to troubleshoot the device opening problems
http://www.cisco.com/warp/public/477/CV/cvtroub5x.shtml#Q6
