[client-to-pix and lan-to-lan tunnels with variable ips]
Carlos A. Silva
Level 3
Level 3
hi,
is it posible to configure a pix to allow:
1.-remote access vpn from cisco client 3.x with xauth
and
2.-at the same time allow a lan-to-lan tunnel from another pix (i'm actually asking about a linksys, but if it works with pix it'll do) with a dsl connection with variable ip addressing.
do you have a sample config?
regards,
c.
i saw the second link, but what confuses me is the fact that:
(here i go with my numbering)
1.-the use of xauth, won't the pix try to xauth the lan2lan connection (i don't want that)
2.-is there a need for the 'set peer' policy within the second policy i would add to the crypto map?
regards (and thanks a lot!)
c.
