Configure P2P connection PIX 7.0.1 problem
ionut.stanescu
I have next problem on my CISCO PIX 515e IOS 7.0.1.
I have defined a basic PAT( i have just only valid ip address ) that working ok, but some of my users want to access some p2p application over pix.
So, for they to have high id inside of p2p application I need to define some access rules over pix to comply these needs:
192.168.100.2:1000 <---> 193.x.x.x:2000
192.168.100.3:1100 <---> 193.x.x.x:2000
Could you advice me ?
Thank you.
mictho
try this....
access-list inside_access_in allow tcp host 192.168.100.2 any eq 1000
cess-list inside_access_in allow tcp host 192.168.100.3 any eq 1000
access-list inside_access_in permit ip any any
access-group inside_access_in in interface inside
write memory
clear xlate
you'll have to do the same on the other end with the ip's you want to allow access.
