CSAMC Installation Problem
kerraj2004
Level 3
Level 3
I beginning to install the CSAMC under the local administator account on the server but get a prompt stating that "Your current OS configuration is not supported. The Supported is Windows Server 2003 R2 (SP1).
I am currently running Windows Server 2003 R2 Standard (SP1)
TradeSecrets
Level 3
Level 3
Hi Kerra.
I had the same issue. Cisco does support that version. If you call tac they will tell you to ignore that message.
But im getting this message on the OS which is supported. You had the same problem getting an error running it on Win 2k3 Standard SP1 R2?
