CSC-SSM-10 Failover Problem
ngtransge
Level 4
Level 4
I have problem with CSC failover, ASA failover work just fine, but CSC don't set up failover. When I configure CSC failover first on Primary device then on Secondary it comes with error (InterScan for CSC SSM could not establish a connection. The software, hardware, and patch version on the peer devices must match. Please reconcile the mismatch that was detected and try again.).
Below are show module 1 detail  of both devices.
Primary
ASA 5500 Series Content Security Services Module-10
Model:              ASA-SSM-CSC-10
Hardware version:   1.0
Serial Number:
Firmware version:   1.0(11)2
Software version:   CSC SSM 6.3.1172.4
MAC Address Range:
App. name:          CSC SSM
App. Status:        Up
App. Status Desc:   CSC SSM scan services are available
App. version:       6.3.1172.4
Data plane Status:  Up
Status:                  Up
HTTP Service:        Up
Mail Service:          Up
FTP  Service:         Up
Activated:              Yes
Mgmt IP addr:       192.168.1.3
Mgmt web port:      8443
Peer IP addr:       <not enabled>
Secondary
Model:              ASA-SSM-CSC-10-K9
Serial Number:
Firmware version:   1.0(11)5
MAC Address Range:
App. name:          CSC SSM
App. Status:        Up
Status:                  Up
HTTP Service:        Up
Mail Service:          Up
FTP  Service:         Up
Activated:              Yes
Mgmt IP addr:       192.168.1.194
Mgmt web port:      8443
As you can see software version on both devices are same, different are only "Model" and "Firmware" can it be the problem ?
Thanks for your help.
csaxena
In terms of ASA module failover, both ASA units that have  AIP-SSM or CSC-SSM modules must be of the same hardware type. For  example, if the primary unit have the ASA-SSM-10 module, the secondary  unit must have the ASA-SSM-10 module.
What we see here is a hardware mismatch and that is the issue.
Here is a document for your reference :
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00807dac5f.shtml#failgi
Hope this helps. Please reply if you need further assistance.
Chirag
P.S.: Please mark this thread as answered if you feel your query is answered. Do.rate helpful posts.
csaxena
Chirag
