CSC-SSM Module Problem
ANGELO DE MASI
Level 3
Level 3
Hi, I installed a CSC-SSM module on ASA 5510. After policy services have been enabled, services works well for a few minutes, after that the cpu usage's module rise to 100% and all http traffic is wholy blocked, till the cpu usage go down.
This happens very frequently and traffic stay blocked for such a long time that it makes the csc-ssm module unusable. It's disabled right now.
ASA version is 8.0(4)and CSC-Module version is 6.3.1172.0.
Please, can you give me any suggestion?
thank you in advance
regards
Angelo
10 Replies 10
Kureli Sankar
Pls. double check and make sure you are not logging http in debug level under the Trend GUI. This may cause cpu spikes.
You are running the latest code.
Also, make sure http inspection is not enabled. (sh run policy-map)
Hi, Thank you for your post.
I checked http debug level and http inspection but both are not enabled.
Any other suggestion?
thanks in advance.
regards
angelo
You can try to disable url filtering under the Trend GUI if you have it enabled to see if that is causing high CPU.
Besides that, you can try to re-image the module.
Pls. follow the below link:
http://supportwiki.cisco.com/ViewWiki/index.php/Re-imaging_the_CSC-SSM#Step_4:_Re-imaging_the_CSC_module
Make sure to save your activation keys and configuration before re-imaging.
only just disabling global policy service matching traffic diverted to module,high CPU usage doesn't happen.
Do you mean reimaging to dowgrade to previous release 6.2.1599.6 ???
bye
angelo
Removing the service-policy doesn't send any traffic to the CSC to be scanned at all.
Pls. try to re-image the module to 6.2.1599.0.bin and then upgrade to 6.2.1599.6.pkg (from the GUI) and see the problem goes away.
Yes, I've reimaged the module to 6.2.1599.6 version and the problem does't appear anymore. It means the new version is bugeg. Isn't it?
Many thanks
Angelo
Very glad to hear that. There are a few known issues in the new code. I have not run into high CPU issue with the new code personally. Pls. stay at 6.2.1599.6.pkg for now until you see another release in the 6.3.11xx code.
Ok I will do so. Thanks for your collaboration.
angelo
We are having a similar issue with 6.3.1172.0 running to 100% CPU.
Do you have a current link to the downgrade procedure?
The 6.3.1172.0 will run at 100% if you have debug logs enabled on it, it is a known problem.
You can go ro 6.3.1172.3.pkg using the procedure described here https://supportforums.cisco.com/docs/DOC-1323#Step_7_Upgrading_to_the_latest_PKG_file
Please rate helpful posts.
PK
