CSM does not show rule numbers when using sections?
pweichmann
Level 3
Level 3
I started using sections in access rules within CSM 4.2 but all the rules that are within these section do not show anymore the rule number in the list.
pweichmann
Level 3
Level 3
The numbers are shown, but you have to expand the column. Somehow cisco makes the no. column to small to see the numbers in a section by default. And they replace the numbers with a dot or two as soon as it is too small to display the numbers.
This appears to be still true in CSM 4.7.0 but the answer appears to still work, too.  Thanks.
