Deny inbound icmp src inside:IP dst interface:IP
Orcun Colakoglu
Hello all,
I am having an issue with ASA5505 firewall setup. We have plenty of interfaces which works fine (likely same configurations, likely same ACL's as letting interface hosts reach required points)
I am able to ping 3 different devices from ASA with their interfaces but I am able only able to ping 2 of them from Core switch. Core switch has the route for ASA inside interface.
The log says "Deny inbound icmp src inside:core-switch dst interfaceM:IP-hostM(type 8, code 0)"
Any ideas as I am lost where this specific interfaceM doesn't work but others works as normal.
31 Replies 31
Core Interface have lower security level 80 than the other port,
so there must ACL allow the ICMP from Core interface to other Interface <high Security 100>.
check this ACL if it allow Core->Host ICMP.
packet-tracer input <Core> icmp <IP of Core> 8 0 <IP of Host> detailed
please do this packet-tracer and share output here, this give us hint were the packet is drop.
Here you go;
  • packet-tracer input inside icmp CoreSwitch 8 0 hostM detailed
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: M
output-status: up
output-line-status: up
Action: allow
As I don't have access to remote host, I believe something else is blocking it. May be a firewall, rule or software on the hostM.
Hi friend
do same packet-tracer and check other interface that work,
under the NAT rule there is deny=true <- this may be issue
under the IP Option there is deny=true <-this may be issue
so we need to make check with other work interface.
-- wrong --
packet-tracer input Micros icmp <core> 0 0 <host> detailed
please repeat as before but this time change the type of ICMP
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
Forward Flow based lookup yields rule:
in id=0x7fd2480836a0, priority=1, domain=permit, deny=false
hits=82343694, user_data=0x0, cs_id=0x0, l3_type=0x8
src mac=0000.0000.0000, mask=0000.0000.0000
dst mac=0000.0000.0000, mask=0100.0000.0000 <- this mask is wrong so the ACL with implicit rule is wrong so you need to add ACL line to permit the access of ICMP request.
input_ifc=inside, output_ifc=any
I think you got a point.
Mac address belongs the hostM which can't reach to hostS.
Also I can't ping hostM from Core.
Here we go;
Phase: 1
Type: ROUTE-LOOKUP
Subtype: Resolve Egress Interface
Result: ALLOW
Config:
found next-hop IP-hostM using egress ifc M
Phase: 2
Type: SUBOPTIMAL-LOOKUP
Subtype: suboptimal next-hop
Result: ALLOW
Config:
ifc selected is not same as preferred ifc
Doing route lookup again on ifc M
Result:
input-interface: M
input-status: up
output-interface: M
output-status: up
Action: drop
Drop-reason: (rpf-violated) Reverse-path verify failed
and my ACL for hostM interface is as below;
access-list M_access_in extended permit ip object obj-M object obj-SRVTrusted
access-list M_access_in extended permit ip object obj-M object obj-PCIServers
access-list M_access_in extended deny ip object obj-M object obj-PrivateClassB
access-list M_access_in extended deny ip object obj-M object obj-PrivateClassC
access-list M_access_in extended permit ip object obj-M any
What should I implement?
please do this packet-tracer to be more check please note the red color mention in command.
packet-tracer input INTERFACE icmp <IP-Source,reach by INTERFACE> 8 0 <IP-Destination> detailed
for example
Host X is direct connect to IN1
Host Y is direct connect to IN2
Host Z is direct connect to IN3
so we will use IN1 in packet-tracer
packet-tracer input IN1 icmp Host X 8 0 Host Y
From which side?
hostM interface, hostM to hostS?
or
inside interface, CoreSwitch to hostM?
I did those on upper replies...
Just to make sure because I don't know the subnet in each Interface or what is subnet reach vis interface.
packet-tracer with Micros 10.160.113.0/? one time you use 83 and other use 183,
the ACL use 10.160.113.64 255.255.255.192
the 83 is OK but 183 is out of subnet connect to Micros!!
that why I confuse.
I Hope this clear for you why we need to check again with exact IP and Interface.
It was a typo error and looks likes this, the area you mentioned is now has correct IP addresses and GW's (%100)
  • packet-tracer input M icmp IP-hostM 8 0 IP-hostS detailed
Phase: 1
Type: ROUTE-LOOKUP
Result: ALLOW
Config:
found next-hop IP-hostS using egress ifc S
Phase: 2
Type: ROUTE-LOOKUP
Result: ALLOW
Config:
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group M_access_in in interface M
in id=0x7fd24ad998d0, priority=13, domain=permit, deny=false
hits=1, user_data=0x7fd23dee4380, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
src ip/id=GWIP-interfaceM, mask=255.255.255.192, port=0, tag=any
dst ip/id=GWIP-interfaceS, mask=255.255.255.224, port=0, tag=any, dscp=0x0
input_ifc=M, output_ifc=any
Phase: 4
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
in id=0x7fd2473df2a0, priority=0, domain=nat-per-session, deny=true
hits=9864828, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0, protocol=0
src ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=any
dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=any, dscp=0x0
input_ifc=any, output_ifc=any
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
in id=0x7fd2482180f0, priority=0, domain=inspect-ip-options, deny=true
hits=889921, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 6
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect icmp
service-policy global_policy global
in id=0x7fd24a243f20, priority=70, domain=inspect-icmp, deny=false
hits=137349, user_data=0x7fd24a23dd40, cs_id=0x0, use_real_addr, flags=0x0, protocol=1
src ip/id=0.0.0.0, mask=0.0.0.0, icmp-type=0, tag=any
dst ip/id=0.0.0.0, mask=0.0.0.0, icmp-code=0, tag=any, dscp=0x0
Phase: 7
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
in id=0x7fd24a255950, priority=70, domain=inspect-icmp-error, deny=false
hits=137349, user_data=0x7fd24a24f770, cs_id=0x0, use_real_addr, flags=0x0, protocol=1
Phase: 8
Type: NAT
Result: ALLOW
Config:
Reverse Flow based lookup yields rule:
hits=9864830, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0, protocol=0
Phase: 9
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
in id=0x7fd24814f400, priority=0, domain=inspect-ip-options, deny=true
hits=1291371, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
input_ifc=SRVTrusted, output_ifc=any
Phase: 10
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 10530252, packet dispatched to next module
Module information for forward flow ...
snp_fp_inspect_ip_options
snp_fp_inspect_icmp
snp_fp_adjacency
snp_fp_fragment
snp_fp_tracer_drop
snp_ifc_stat
Module information for reverse flow ...
snp_fp_inspect_icmp
snp_fp_adjacency
snp_fp_fragment
snp_fp_tracer_drop
snp_ifc_stat
Phase: 11
Type: ROUTE-LOOKUP
Result: ALLOW
Config:
Phase: 12
Type: ADJACENCY-LOOKUP
Subtype: next-hop and adjacency
Result: ALLOW
Config:
adjacency Active
next-hop mac address 0050.5691.4269 hits 67914 reference 14
Result:
input-interface: M
input-status: up
output-interface: S
output-status: up
Action: allow
packet-tracer input Core icmp IP-Core 8 0 IP-hostM detailed
packet-tracer input Core icmp IP-COre 8 0 IP-hostS detailed
since you mention Core->HostS is allow
Core->HostM is drop
finally only this,
  • packet-tracer input inside icmp IP-CoreSwitch 8 0 IP-hostM detailed
Phase: 1
Type: ROUTE-LOOKUP
Result: ALLOW
Config:
Phase: 2
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group inside_access_in in interface inside
access-list inside_access_in extended permit ip object obj-inside object obj-M
in id=0x7fd24a7b2d40, priority=13, domain=permit, deny=false
hits=8, user_data=0x7fd23dee09c0, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
src ip/id=network-inside, mask=255.255.255.224, port=0, tag=any
dst ip/id=network-hostM, mask=255.255.255.192, port=0, tag=any, dscp=0x0
Phase: 3
Type: NAT
Result: ALLOW
Config:
hits=12619505, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0, protocol=0
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
in id=0x7fd24808ace0, priority=0, domain=inspect-ip-options, deny=true
hits=4763603, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 5
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
inspect icmp
in id=0x7fd24a23f4a0, priority=70, domain=inspect-icmp, deny=false
hits=261411, user_data=0x7fd24a23dd40, cs_id=0x0, use_real_addr, flags=0x0, protocol=1
Phase: 6
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
in id=0x7fd24a250ed0, priority=70, domain=inspect-icmp-error, deny=false
hits=261411, user_data=0x7fd24a24f770, cs_id=0x0, use_real_addr, flags=0x0, protocol=1
Phase: 7
Type: NAT
Result: ALLOW
Config:
hits=12619507, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0, protocol=0
Phase: 8
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
hits=1203810, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 9
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 13796669, packet dispatched to next module
snp_fp_inspect_icmp
snp_fp_adjacency
snp_fp_fragment
snp_fp_tracer_drop
snp_ifc_stat
snp_fp_inspect_icmp
snp_fp_adjacency
snp_fp_fragment
snp_fp_tracer_drop
snp_ifc_stat
Phase: 10
Type: ROUTE-LOOKUP
Result: ALLOW
Config:
found next-hop IP-hostS using egress ifc M
Phase: 11
Result: ALLOW
Config:
adjacency Active
next-hop mac address 00a0.a426.2284 hits 0 reference 8
Result:
input-status: up
output-interface: M
output-status: up
Action: allow
  • packet-tracer input inside icmp IP-CoreSwitch 8 0 hostS detailed
Phase: 1
Type: ROUTE-LOOKUP
Result: ALLOW
Config:
found next-hop hostS using egress ifc S
Phase: 2
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-list inside_access_in extended permit ip any any
in id=0x7fd2485ea6c0, priority=13, domain=permit, deny=false
hits=4077610, user_data=0x7fd23dee5d00, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
Phase: 3
Type: NAT
Result: ALLOW
Config:
hits=12620098, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0, protocol=0
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
hits=4764989, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 5
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
inspect icmp
hits=261430, user_data=0x7fd24a23dd40, cs_id=0x0, use_real_addr, flags=0x0, protocol=1
Phase: 6
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
hits=261430, user_data=0x7fd24a24f770, cs_id=0x0, use_real_addr, flags=0x0, protocol=1
Phase: 7
Type: NAT
Result: ALLOW
Config:
hits=12620100, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0, protocol=0
Phase: 8
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
hits=1807908, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
input_ifc=S, output_ifc=any
Phase: 9
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 13798335, packet dispatched to next module
snp_fp_inspect_icmp
snp_fp_adjacency
snp_fp_fragment
snp_fp_tracer_drop
snp_ifc_stat
snp_fp_inspect_icmp
snp_fp_adjacency
snp_fp_fragment
snp_fp_tracer_drop
snp_ifc_stat
Phase: 10
Type: ROUTE-LOOKUP
Result: ALLOW
Config:
Phase: 11
Result: ALLOW
Config:
adjacency Active
next-hop mac address 0050.5691.4269 hits 12447 reference 10
Result:
input-status: up
output-interface: S
output-status: up
Action: allow
I hard try to find what is reason the ICMP drop but still not find any reason,
we can use following command to see drop reason
ciscoasa# show asp drop
 1-check the count for each drop reason
2-do ping "not packet-tracer"
3- check the count for each drop reason, which one is increase after pin?
I think it MAC address failed!! why because the mac address in last phase of packet-tracer is miss "NOT HIT"
and I think this because the subnet mask config of interface is different than the  subnet direct connect to it.
Note:-please confirm it not BVI.
Good Luck Friend.
No it is not BVI and thanks for all your inputs, spent time and help.
I can't track asp drop because information increments to fast but when I check from ASDM the error is as below;
  • 19 Mar 16 2022 02:35:27 302021 core-switch 0 IP-hostM 0 Teardown ICMP connection for faddr core-switch/0 gaddr IP-hostM/0 laddr IP-hostM/0 type 8 code 0
