Device administration using certificates
networker99
Level 5
Level 5
Rather then specifying SSH subnets for device administration, is it possible to use certificates instead?
wong34539
Level 11
Level 11
Here are the basic steps for enrolling with a CA and getting an identity certificate to use for authenticating tunnels. This example shows both automatic (SCEP) enrollment and manual enrollment. For information on fields not defined in this procedure, click the Help button.
1. Generating a key pair for the identity certificate. The key pair is RSA.
2. Creating a trustpoint.
3. Configuring an enrollment URL.
4. Authenticating the CA.
5. Enrolling with the CA, which places an identity certificate onto the security appliance
