DHCP Proxy Problem
royda1061
Community Member
Jun 16, 2004, 8:21am PST
I'm using the "DHCP Network Scope" field in order to provide a specific scope for a Group of users. The VPN concentrator for the DHCP Discover request uses its own IP address into the IP source field and inserts into the GIADDR field of the DHCP Discover message the "DHCP Network Scope" information. The DHCP server then uses the GIADDR as the return address and consequently my VPN concentrator doesn't receive the DHCP Offer.
Does anybody have a solution or information?
Thanks.
Regards.
David Roy.
afakhan
Level 9
Level 9
Hi David,
Please describe your topology (VPN3K scope, VPN3K interface subnets, any FW etc.).
What you have described seems the way it works.
Afaq
