difference between ASDM versions
samarthashetty
Frequent Visitor
Frequent Visitor
Guys,
can anyone please let me know difference between these two files below and which one we need to upload it to ASA.
1. Cisco Adaptive Security Device Manager for ASA 9.1-9.12 requires Oracle JRE.
2. Cisco Adaptive Security Device Manager for ASA 9.1-9.12 integrated with OpenJRE.
Samarth
ppreenja
Both ASDM versions work the same and there is not better version. The one difference is that if you cannot download the Oracle's Java you might decide to use the OpenJRE ASDM version since OpenJRE is open source while OracleJRE is proprietary.
I hope the above answers your query.
Cheers,
Pratham
ppreenja
Cheers,
Pratham
Thanks a lot
regards
samarth
