Difference between show running-config and more system:running-config
dzuba
Why need two similar command for see running-config?
2 Accepted Solutions
@dzuba the output is mostly the same, you must use the "more system:running-config" to display encrypted keys, i.e. VPN Pre-Shared Keys, these are not displayed in cleartext when just running "show run" command.
in IOS
The more system:running-config command displays the same output as the show running-config command.
in ASA
When you view a configuration file that you have saved using the more command, tunnel-group passwords in the configuration file appear in clear text.
MHM
6 Replies 6
Leo Laohoo
Running-config is stored in different partition (hardware dependent).
d0nprintup1
 The more command can view the contents of any file, not just the running configuration; see the command reference for more information.
dzuba
Is output in this case the same?
Yes, the output is the same.
in IOS
in ASA
MHM
