Drop with Packet Capture?help
Ibrahim Jamil
Level 6
Level 6
Hi Folks
how to start troubleshoot the Below:
the user source address 172.16.3.2 (Behind ASA-1
the destination SIP Server: 10.100.100.100 (Behind ASA-2)
packet-tracer input outside udp 172.16.3.2 4263  10.100.100.100 sip
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Found no matching flow, creating a new flow
Phase: 3
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Phase: 4
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Result:
input-interface: DMZ
input-status: up
input-line-status: up
output-interface: DMZ
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
38 Replies 38
Hi Sankar, r u sure its bolcked by IPS module? if so Pls How to exempt this traffic from being scanned by the ips module,ps help
this is my ACL regarding AIP-SSM
access-list AIP-SSM  extended permit ip any any
btw sanker I learnt too much from this conversation,Thank you
Ibrahim,
You can add a deny line 1 for the flow in question and then test.
access-list AIP-SSM line 1 deny ip host x.x.x.x host y.y.y.y
-KS
Hi Sankar
see the below
Feb 04 2011 07:53:29: %ASA-2-106006: Deny inbound UDP from 172.16.3.2/5060 to 100.100.100.100/5060 on interface outside
that deny message says that it is being denied on the interface so that means that the ACL you mentioned is not applied on the interface coming in.You should allow the traffic on the interface otherwise the traffic will continue showing as denied on the packet-tracer.
in the place where i issued the packet-tracer there is ACP permit ip any any on both interfaces inside and outside
very strange because that syslog message tells it is denied by the interface not by the access-group. Can you send the show run access-list and show run access-group? just to confirm.
access-list OUT extended permit ip any any
access-list OUT extended permit icmp any any
access-list IN extended permit ip any any
access-list IN extended permit icmp any any
access-group OUT in interface outside
access-group IN in interface inside
ok, interface ACLs are not the issue. Did you tried what Sankar suggested about making an exemption of the traffic sent to the IPS?
Is that ACL applied to an interface?
IF you could share the config that will help a lot.
Without acl deny in the syslog means there is no static traslation to allow the tcp 5060 packet
from outside to inside.
Does this ASA have SIP inspection enabled?
Is there a static 1-1 translation for the SIP server's iP address on this ASA?
Config will certainly help.
-KS
Yes guys
sip inspect is enabled under service-policy
what do y man withthe  below
Try Sankar's suggestion:
access-list AIP-SSM line 1 deny ip host 172.16.3.2 host 10.100.100.100
Then try the packet tracer
After traffc exemption  from being scanned ,I received the below:
Feb 04 2011 08:59:17: %ASA-2-106001: Inbound TCP connection denied from 172.16.3.2/5060 to 100.100.100.100/5060 flags SYN  on interface outside
By mistake I wrote incorrectly the ACL for the IP. Can you check the destination IP is the IP 100.100.100.100 instead of 10.100.100.100.
Aditionally can you tell us if there is some type of NAT translation for the traffic flowing from the outside to the inside?
its normal translation on the asa ,I dont have any servers in this site
global (outside) 1 interface
nat (inside) 1  0 0
