Dual ISP Connection in PIX. Will it work?
vipinrajrc
Level 3
Level 3
Hi Experts,
I need to implement another ISP circuit in my client's PIX515E v6.3.3. But  in this  PIX i was not able to configure backup command. When i checked i found that it support only after 7.2. So i decide to configure another default route with AD as 1 and Change the existing to a higher value. I want to implement the new one as the primary and the old one as the secondary. will it works?
Vipin
Thanks and Regards, Vipin
Jennifer Halim
No, you can't just have 2 default routes with different administrative distance because if the primary ISP is not available, the PIX firewall will not know.
For PIX to automatically failover to the secondary ISP, you would need to configure track/sla on PIX v7.x and above so it can determine when it's down, as per the following sample config:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00806e880b.shtml
With version 6.x, when primary ISP is down, you would need to manually disconnect or shutdown the PIX interface that connects to the primary ISP for the secondary ISP to work. And you would also need to manually fail it back to the primary ISP when it's back up.
Hope that answers your question.
As i mentioned i configured another interface with the new ip address which is provided by the ISP. From the PIX itself i got ping to that ip. But from outside i didnt get ping to the IP address.
I just configured that IP address,Sec-level to zero. I didnt configure PAT. but i didnt get ping to this interface from outside.
what might be the issue?
thanks and regards
Vipin
Please kindly share the configuration.
Please check if you have any "icmp" command on any interface. If you do, then you would need to also explicitly configure this new interface to be allowed with ping.
The command will be "icmp permit any "
