Error: "Chassis operating state network module Power-problem"
SegNetSantander
Community Member
Hello team,
we have this error message on one of the appliances (Firepower 2140). I do not have enough information about what we can do in order to do some more deep analysis.
The network interfaces seem to be ok (link up).
The firepower have the version 7.1.0.1
Thanks in advance!
Mark Elsen
   - Connect to the firepower with : https://cway.cisco.com/cli/, at the top left press and or run 'System Diagnostics'
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
balaji.bandi
check what is causing the issue : (do you have any SFP installed ?)
# show environment expand detail
 - check other side where this is connected to the switch, do you see any errors?
BB
SegNetSantander
Community Member
Thanks both for the answers!
I use this combination and I can view that one power supply have an energy issue.
connect fxos
show chassis enviroment expand
PSU 1:
Overall Status: Powered Off
Operability: Unknown
Power State: Off
Voltage Status: Unknown
thanks!
now you know what to do, check the physical inspection and fix it.
hope that resolves the issue, if so feedback here what is the outcome
BB
