Failover Ethernet1/11 (Failed - No Switchover)
rikkm4n
Hi all!
I have a question about ASA cluster failover. Failover LAN interface shows the following error:
CGD600167DVPN1/sec/act# sh fail
Failover On
Failover unit Secondary
Failover LAN Interface: Failover Ethernet1/11 (Failed - No Switchover)
Reconnect timeout 0:00:00
Unit Poll frequency 1 seconds, holdtime 15 seconds
Interface Poll frequency 5 seconds, holdtime 25 seconds
Interface Policy 1
Monitored Interfaces 6 of 1293 maximum
MAC Address Move Notification Interval not set
failover replication http
Version: Ours 9.12(4)67, Mate 9.12(4)67
Serial Number: Ours JAD2245003H, Mate JAD2245006Q
Last Failover at: 11:41:59 WET Dec 2 2024
But interface is up:
CGD600167DVPN1/sec/act# sh int eth1/11
Interface Ethernet1/11 "Failover", is up, line protocol is up
Hardware is EtherSVI, BW 1000 Mbps, DLY 10 usec
Description: LAN Failover Interface
And the sync state is ok:
CGD600167DVPN1/sec/act# sh fail state
State Last Failure Reason Date/Time
This host - Secondary
Active None
Other host - Primary
Standby Ready Ifc Failure 12:18:44 WET Dec 2 2024
outside: No Link
====Configuration State===
Sync Done
====Communication State===
Can't ping the other peer over failover LAN interface:
CGD600167DVPN1/sec/act# ping 1.1.1.5
Sending 5, 100-byte ICMP Echos to 1.1.1.5, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Should i be worried if cluster fails over?
15 Replies 15
Reload of the standby unit did the trick.
Ping works across failover links and the error message is gone. Failover also worked as expected.
