FirePower 2110 Port LED indicator
Roy Lee
I am setting up FirePower 2110. Each physical Ethernet port has 2 LED, "L" and "S".
According to cisco document, "L" is Link/Activity, "S" is speed (1 flash=10 Mbit, 2=100 Mbit, 3=1 Gbit) .
When I connect a port to 100MB Switch, "L" LED is on and flash. I can ping this port after assign it an IP.
When I connect the port to Gigabit switch, only the "S" LED is on and solid. I can ping this port after assign it an IP.
Is that normal?
Or need to change setting?
Please advise.
Roy
Roy Lee
Hi There,
Anybody help?
Roy
