Firepower 4110 Security Module/Engine Not Responding/Inaccessible
alex.f.
Level 3
Level 3
I am working on a regular update cycle with several Firepower 4110 / 2110 / 2140.
I installed the update from 6.6.4 to 6.6.5 on up to eight  HA Cluster but the last one failed.
(so four identical Cluster with Firepower 4110 HA Cluster)
So the first Instance of the HA Cluster did get the 6.6.5 but never come back online.
(the second is now Active on 6.6.4)
I tried the following Steps ( mostly in that order) to get some information:
ping the mgmt form the logical device -> not reachable
connecting to the 4110 Chassis -> OK
(there are some errors in the overview tab see attachment)
Logical Devices lists the FTD in state "Security module not responding"
restarting the FTD logical Device -> no effect
disable/enable the FTD logical Device -> no effect
Security Engine lists one Hardware State "Inaccessible" service state "not responding" Power "off"
I tried to power on/off the module -> no effect
I tried to power cycle the module (GUI and CLI) -> no effect
I tried to power reinitialize the module (GUI and CLI) -> no effect
Chassis# scope ssa
Chassis /ssa # scope slot 1
Chassis /ssa/slot # show detail
Slot:
Slot ID: 1
Log Level: Info
Admin State: Ok
Oper State: Not Responding
Disk Format State: Ok
Disk Format Status: 0%
Clear Log Data: Available
Error Msg:
Chassis /ssa/slot #
Are there any things I can do or check instead of rebooting the Chassis ?
Marvin Rhoads
Based on what you have done so far, I would say a chassis reboot is a logical next step. If you have physical access, a cold reboot (full power off) is preferred. If you have console access I would recommend using it and capturing the output of the boot and initialization process.
If that fails, then I would open a TAC case.
Marvin Rhoads
Thank you Marvin for your quick response.
Currently I'm remote and have no physical access until Monday or maybe Tuesday.
Are all other log files written to the Device and accessible after the cold reboot?
I will do the cold reboot with a console log output and post my findings.
thx
Alex
I did a cold reboot and after 20 Minutes the FTD / HA was up and running.
Force Active/Standby Switch was successful.
Nevertheless, I now have a HA with two versions 6.6.5 / 6.6.4.
In the updater of the FMC I can also not select a single FTD but only the HA cluster.
So I will have to update the whole HA cluster again.
