Firepower 8250 Drain of unprocessed events from Connection Events
CSC011240286
Hi There
We have the below critical alert from one of our sourcefire devices it comes and goes.
Drain of unprocessed events from Connection Events.
Any ideas would be appreciated.
yogdhanu
Hi Yogdhanu
I take it the below answer from Claudiu Cismaru posted on the forum  is correct?
If the FP module is configured to send the events to FMC, then you could have:
- pretty slow connection between the module and FMC and a high number of generated connection events, which are lagged behind
- hung process on FMC which receive the events. There were some bugs related on this.
What's the sensor and FMC version?
