firepower problem
gabuun999
Community Member
Hello
We have purchased a new cisco firepower 7010 series
I have assigned managamnet ip address and can access using the browser.
My problem is that the browser is not showing all features except few
best regards
8 Replies 8
Pujita Patni
What features are you not able to see on the browser ? Do you have another device that shows more features compared to this device ?
Pujita Patni
Rate if it helps !
Dear Pujitta
Please check the pictures i gave at botton
What I dont have is like licence activation feature.
please the check the screeen shots i have given ,,you will notice there are no many features at tool bar
Can i use ciscofire power alone with out putting it inside asa
firewall
thanks alot
By Cisco Firepower if you mean the 7010 device, then yes you can use it without ASA. You will just need the Firesight Management Center to manage it.
Pujita Patni
Rate if it helps !
Hello Team,
Refer the release notes to setup the Firesight Management Center and Firepower sensor .
http://www.cisco.com/c/en/us/td/docs/security/firesight/5407/relnotes/FireSIGHT-System-Release-Notes-version5407-and-5416.html
Rate and correct if the post helps you
Jetsy
Those are all the tabs you would see on a 7110 device. It does not have all the tabs compared to the Defense Center/Management Center.
I checked one in the lab too to confirm. What you are seeing is what is expected.
Pujita Patni
Rate if it helps !
Thanks a lot pujitaa
How can I get management center
Does it not come with device or should I download it separately
This is new to me please guide me how to configure it to the best and get the most features as well
thanks
From your previous comment I understand that you have a 7010 device. You will need a Firesight Management Center to manage this. You can either use a hardware device for this or install it on the VM. You will need License in either cases.
Here is the link to deploy it on a VM:
http://www.cisco.com/c/en/us/support/docs/security/firesight-management-center-virtual-appliance/118645-configure-firesight-00.html
Here are details about the 7000 Series Appliance that you have:
http://www.cisco.com/c/en/us/products/security/firepower-7000-series-appliances/index.html
If you want to use the Firepower services on the ASA, you can install the Firepower module on your ASA and manage it with the Firesight Management Center or the ASDM.
http://www.cisco.com/c/en/us/products/security/asa-firepower-services/index.html
Pujita
Rate if it helps !
