Firepower4100 ASA, is it possible not occupying a data interface for ASA management?
fraserC
FPR 4100 comes with 8x10G SPF network module. via Quick start Guide, it needs to assgin a one of these 8 ports for ASA management. It is too expensive if only for mgmt access.
I may configure inside interface to allow mgmt HTTP/SSH access. However I am not able to release the assigned asa mgmt port via FDM. Is it possible to save this port for data?
Confirmed with Cisco that it is true on FP4100 you have to assign a data port as dedicated ASA management interface. FP2100 is different, it shares the chassis MGT interface for ASA management.
Dennis Mink
the quick start guide only seems to suggest using these ports when you set upo a port channel. only then do you need to choose between managament and data.
if you just use the management port for management and you have no need to add a port channel for management, you can use the 8 sfps for data.
Please remember to rate useful posts, by clicking on the stars below.
If you are running ASA on the FP4100 then no you do not need to dedicate a port for management.  If this is FP4100 running FTD then yes you need to have a dedicated management port.
Please remember to select a correct answer and rate helpful posts
That's correct. Thanks for confirming the TAC feedback.
