firewall problem
joseph_samaha
Community Member
Hi all, i have one pix 515 that is having a problem, the configuration is very simple, it works fine but intermittently some IPs can't pass through the firewall even though they are allowed through the ACL, i replaced it with one new ASA for testing, but still have the same problem, i have to reset the firewall in order to be able to surf through the IPs (and the IP that are having problems are not always the same), thanks for helping me
srue
Level 11
Level 11
Could be a license issue.
post the outputs of "show version", and a sanitized version of "show run "....
Samer Labaky
Community Member
these IPs are used for which application ?
