Flow is denied by configured rule, Drop-location: frame snp
Suhrob Samiev
I'm managing two FTDs using Cisco FMC 7.6, and I have no any critical health issues.
Firewall set up in a routed mode, assigned such IPs
Ethernet 1/1 ouside -> ISP IP
Ethernet 3/1: inside - > 192.168.15.1/24
Ethernet 4/1: dmz ->    192.168.50.2/28
VM -> 192.168.15.100
Mikrotik Router connected with Ethernet 4/1, 192.168.50.1/28
Routes
S* 0.0.0.0 0.0.0.0 [1/0] via 37.98.x.x, wan
C 37.98.159.32 255.255.255.240 is directly connected, wan
L 37.98.159.42 255.255.255.255 is directly connected, wan
S 192.168.10.0 255.255.255.0 [1/0] via 192.168.50.1, dmz
C 192.168.15.0 255.255.255.0 is directly connected, inside
L 192.168.15.1 255.255.255.255 is directly connected, inside
C 192.168.50.0 255.255.255.248 is directly connected, dmz
L 192.168.50.2 255.255.255.255 is directly connected, dmz
Auto NAT: inside_zone, outside_zone dynamic
Access lists allow to access internet from 192.168.15.100
access-list cached ACL log flows: total 0, denied 0 (deny-flow-max 4096)
alert-interval 300
access-list CSM_FW_ACL_; 16 elements; name hash: 0x4a69e3f3
access-list CSM_FW_ACL_ line 1 remark rule-id 9998: PREFILTER POLICY: Default Tunnel and Priority Policy
access-list CSM_FW_ACL_ line 2 remark rule-id 9998: RULE: DEFAULT TUNNEL ACTION RULE
access-list CSM_FW_ACL_ line 3 advanced permit ipinip any any rule-id 9998 (hitcnt=0) 0xf5b597d6
access-list CSM_FW_ACL_ line 4 advanced permit udp any eq 3544 any range 1025 65535 rule-id 9998 (hitcnt=0) 0x46d7839e
access-list CSM_FW_ACL_ line 5 advanced permit udp any range 1025 65535 any eq 3544 rule-id 9998 (hitcnt=0) 0xaf1d5aa5
access-list CSM_FW_ACL_ line 6 advanced permit 41 any any rule-id 9998 (hitcnt=0) 0x06095aba
access-list CSM_FW_ACL_ line 7 advanced permit gre any any rule-id 9998 (hitcnt=0) 0x52c7a066
access-list CSM_FW_ACL_ line 8 remark rule-id 268434450: ACCESS POLICY: AccPolicy - Mandatory
access-list CSM_FW_ACL_ line 9 remark rule-id 268434450: L7 RULE: No Gambling Rule
access-list CSM_FW_ACL_ line 10 advanced permit ip ifc inside any ifc wan any rule-id 268434450 (hitcnt=1232) (Last Hi t=06:30:05 UTC Dec 11 2024) 0xe2dae483
access-list CSM_FW_ACL_ line 11 remark rule-id 268434451: ACCESS POLICY: AccPolicy - Mandatory
access-list CSM_FW_ACL_ line 12 remark rule-id 268434451: L7 RULE: New-Rule-#4-ALLOW
access-list CSM_FW_ACL_ line 13 advanced permit ip ifc dmz any ifc inside any rule-id 268434451 (hitcnt=0) 0x8377aa96
access-list CSM_FW_ACL_ line 14 remark rule-id 268434454: ACCESS POLICY: AccPolicy - Mandatory
access-list CSM_FW_ACL_ line 15 remark rule-id 268434454: L7 RULE: New-Rule-#9-ALLOW
access-list CSM_FW_ACL_ line 16 advanced permit ip object 192.168.50.0 object netw-192.168.15.0 rule-id 268434454 (hit cnt=0) 0x0def8c30
access-list CSM_FW_ACL_ line 16 advanced permit ip 192.168.50.0 255.255.255.0 192.168.15.0 255.255.255.0 rule-id 268 434454 (hitcnt=0) 0x0def8c30
access-list CSM_FW_ACL_ line 17 remark rule-id 268434455: ACCESS POLICY: AccPolicy - Mandatory
access-list CSM_FW_ACL_ line 18 remark rule-id 268434455: L7 RULE: New-Rule-#7-ALLOW
access-list CSM_FW_ACL_ line 19 advanced permit ip ifc inside any object 50.2 rule-id 268434455 (hitcnt=631) (Last Hit =06:16:45 UTC Dec 11 2024) 0x3a307ed1
access-list CSM_FW_ACL_ line 19 advanced permit ip ifc inside any host 192.168.50.2 rule-id 268434455 (hitcnt=631) ( Last Hit=06:16:45 UTC Dec 11 2024) 0x3a307ed1
access-list CSM_FW_ACL_ line 20 remark rule-id 268434452: ACCESS POLICY: AccPolicy - Mandatory
access-list CSM_FW_ACL_ line 21 remark rule-id 268434452: L7 RULE: New-Rule-#3-ALLOW
access-list CSM_FW_ACL_ line 22 advanced permit ip ifc inside any ifc dmz any rule-id 268434452 (hitcnt=17) (Last Hit= 05:59:07 UTC Dec 11 2024) 0x8be62cea
access-list CSM_FW_ACL_ line 23 remark rule-id 268434453: ACCESS POLICY: AccPolicy - Mandatory
access-list CSM_FW_ACL_ line 24 remark rule-id 268434453: L7 RULE: New-Rule-#8-ALLOW
access-list CSM_FW_ACL_ line 25 advanced permit ip object netw-192.168.15.0 object 192.168.50.0 rule-id 268434453 (hit cnt=0) 0x5be3d9eb
access-list CSM_FW_ACL_ line 25 advanced permit ip 192.168.15.0 255.255.255.0 192.168.50.0 255.255.255.0 rule-id 268 434453 (hitcnt=0) 0x5be3d9eb
access-list CSM_FW_ACL_ line 26 remark rule-id 268434433: ACCESS POLICY: AccPolicy - Mandatory
access-list CSM_FW_ACL_ line 27 remark rule-id 268434433: L7 RULE: INTERNET-15#-ALLOW
access-list CSM_FW_ACL_ line 28 advanced permit ip ifc inside object netw-192.168.15.0 ifc wan any4 rule-id 268434433 (hitcnt=119033) (Last Hit=06:36:25 UTC Dec 10 2024) 0xa55bc74c
access-list CSM_FW_ACL_ line 28 advanced permit ip ifc inside 192.168.15.0 255.255.255.0 ifc wan any4 rule-id 268434 433 (hitcnt=119033) (Last Hit=06:36:25 UTC Dec 10 2024) 0xa55bc74c
access-list CSM_FW_ACL_ line 29 remark rule-id 268434434: ACCESS POLICY: AccPolicy - Mandatory
access-list CSM_FW_ACL_ line 30 remark rule-id 268434434: L7 RULE: New-Rule-#2-ALLOW
access-list CSM_FW_ACL_ line 31 advanced permit object-group ping ifc wan any object Public-IP rule-id 268434434 (hitc nt=0) 0x8f8ac98b
access-list CSM_FW_ACL_ line 31 advanced permit icmp ifc wan any4(0xf0050000) host 37.98.159.42(0x25629f2a) rule-id 268434434 (hitcnt=0) 0x2e0dd838
access-list CSM_FW_ACL_ line 32 remark rule-id 268434441: ACCESS POLICY: AccPolicy - Default
access-list CSM_FW_ACL_ line 33 remark rule-id 268434441: L7 RULE: Public access-#ALLOW
access-list CSM_FW_ACL_ line 34 advanced permit tcp ifc wan any ifc inside object VM-15100 object-group HTTP rule-id 2 68434441 (hitcnt=531) (Last Hit=05:17:19 UTC Dec 11 2024) 0x5a62c12a
access-list CSM_FW_ACL_ line 34 advanced permit tcp ifc wan any4(0xf0050000) ifc inside host 192.168.15.100(0xc0a80f 64) eq www rule-id 268434441 (hitcnt=531) (Last Hit=05:17:19 UTC Dec 11 2024) 0x177c560b
access-list CSM_FW_ACL_ line 35 advanced permit tcp ifc wan any ifc inside object VM-15100 object-group RDP rule-id 26 8434441 (hitcnt=46) (Last Hit=06:28:39 UTC Dec 11 2024) 0x51cc0275
access-list CSM_FW_ACL_ line 35 advanced permit tcp ifc wan any4(0xf0050000) ifc inside host 192.168.15.100(0xc0a80f 64) eq 3389 rule-id 268434441 (hitcnt=46) (Last Hit=06:28:39 UTC Dec 11 2024) 0xaf1f67fe
access-list CSM_FW_ACL_ line 36 remark rule-id 268434432: ACCESS POLICY: AccPolicy - Default
access-list CSM_FW_ACL_ line 37 remark rule-id 268434432: L4 RULE: DEFAULT ACTION RULE
access-list CSM_FW_ACL_ line 38 advanced deny ip any any rule-id 268434432 event-log flow-start (hitcnt=24) (Last Hit= 07:01:06 UTC Dec 10 2024) 0x97aa021a
Currently cannot ping locally connected interface 192.168.50.2 from VM 192.168.15.100
Capturing packets show access is dropped but in access policy I have allowed any traffic between inside_zone and dmz_zone.
4 packets captured
1: 06:16:31.215900 192.168.15.100 > 192.168.50.2 icmp: echo request
Phase: 1
Type: CAPTURE
Subtype:
Result: ALLOW
Elapsed time: 7680 ns
Config:
Additional Information:
MAC Access list
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
MAC Access list
Phase: 3
Type: ROUTE-LOOKUP
Subtype: No ECMP load balancing
Result: ALLOW
Elapsed time: 18432 ns
Config:
Destination is locally connected. No ECMP load balancing.
Found next-hop 192.168.50.2 using egress ifc dmz(vrfid:0)
Phase: 4
Type: OBJECT_GROUP_SEARCH
Subtype:
Result: ALLOW
Elapsed time: 26112 ns
Config:
Source object-group match count: 0
Source NSG match count: 0
Destination NSG match count: 0
Classify table lookup count: 1
Total lookup count: 1
Duplicate key pair count: 0
Classify table match count: 4
Phase: 5
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Elapsed time: 256 ns
Config:
access-group CSM_FW_ACL_ global
access-list CSM_FW_ACL_ remark rule-id 268434455: ACCESS POLICY: AccPolicy - Mandatory
access-list CSM_FW_ACL_ remark rule-id 268434455: L7 RULE: New-Rule-#7-ALLOW
This packet will be sent to snort for additional processing where a verdict will be reached
Phase: 6
Type: CONN-SETTINGS
Subtype:
Result: ALLOW
Config:
class-map class-default
match any
policy-map global_policy
class class-default
set connection advanced-options UM_STATIC_TCP_MAP
service-policy global_policy global
Phase: 7
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
Phase: 8
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 9
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Elapsed time: 25088 ns
Config:
class-map inspection_default
match default-inspection-traffic
class inspection_default
inspect icmp
Phase: 10
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Elapsed time: 3072 ns
Config:
Phase: 11
Type: ACCESS-LIST
Subtype:
Result: DROP
Elapsed time: 31744 ns
Config:
Implicit Rule
Result:
input-interface: inside(vrfid:0)
input-status: up
input-line-status: up
output-interface: dmz(vrfid:0)
output-status: up
output-line-status: up
Action: drop
Time Taken: 120832 ns
Drop-reason: (acl-drop) Flow is denied by configured rule, Drop-location: frame snp_sp_handle_flow_drop:4208 flow (NA)/NA
2: 06:16:36.130776 192.168.15.100 > 192.168.50.2 icmp: echo request
Phase: 1
Type: CAPTURE
Subtype:
Result: ALLOW
Config:
MAC Access list
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
MAC Access list
Phase: 3
Type: ROUTE-LOOKUP
Result: ALLOW
Elapsed time: 19968 ns
Config:
Phase: 4
Subtype:
Result: ALLOW
Elapsed time: 27136 ns
Config:
Phase: 5
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Elapsed time: 512 ns
Config:
Phase: 6
Type: CONN-SETTINGS
Subtype:
Result: ALLOW
Config:
match any
class class-default
Phase: 7
Type: NAT
Result: ALLOW
Config:
Phase: 8
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 9
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Elapsed time: 24576 ns
Config:
inspect icmp
Phase: 10
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Elapsed time: 3584 ns
Config:
Phase: 11
Type: ACCESS-LIST
Subtype:
Result: DROP
Elapsed time: 30208 ns
Config:
Implicit Rule
Result:
input-status: up
output-status: up
Action: drop
Time Taken: 113664 ns
What could be the problem?
Suhrob
6 Replies 6
please use detail with your packet tracer and share result here
MHM
please find the output results below:
> show capture CAP detail
168 packets captured
1: 06:01:07.608550 000c.29c5.3113 a410.b6f1.5526 0x0800 Length: 74
192.168.15.100 > 192.168.50.2 icmp: echo request (ttl 128, id 13624)
2: 06:01:12.608489 000c.29c5.3113 a410.b6f1.5526 0x0800 Length: 74
192.168.15.100 > 192.168.50.2 icmp: echo request (ttl 128, id 13625)
3: 06:01:17.608626 000c.29c5.3113 a410.b6f1.5526 0x0800 Length: 74
192.168.15.100 > 192.168.50.2 icmp: echo request (ttl 128, id 13626)
4: 06:01:22.608901 000c.29c5.3113 a410.b6f1.5526 0x0800 Length: 74
192.168.15.100 > 192.168.50.2 icmp: echo request (ttl 128, id 13627)
5: 06:01:27.609358 000c.29c5.3113 a410.b6f1.5526 0x0800 Length: 74
192.168.15.100 > 192.168.50.2 icmp: echo request (ttl 128, id 13628)
6: 06:01:32.609282 000c.29c5.3113 a410.b6f1.5526 0x0800 Length: 74
192.168.15.100 > 192.168.50.2 icmp: echo request (ttl 128, id 13629)
7: 06:01:37.609099 000c.29c5.3113 a410.b6f1.5526 0x0800 Length: 74
192.168.15.100 > 192.168.50.2 icmp: echo request (ttl 128, id 13630)
8: 06:01:42.609541 000c.29c5.3113 a410.b6f1.5526 0x0800 Length: 74
192.168.15.100 > 192.168.50.2 icmp: echo request (ttl 128, id 13631)
9: 06:01:47.609465 000c.29c5.3113 a410.b6f1.5526 0x0800 Length: 74
192.168.15.100 > 192.168.50.2 icmp: echo request (ttl 128, id 13632)
10: 06:01:52.609663 000c.29c5.3113 a410.b6f1.5526 0x0800 Length: 74
192.168.15.100 > 192.168.50.2 icmp: echo request (ttl 128, id 13633)
I will send you PM
thanks
MHM
That will never work because the ASA and the FTD firewalls are designed not to allow reaching an interface from another interface sitting on the opposite side. In your case you are trying to ping the firewall interface 192.168.50.2 from a host in the inside network, this is not allowed by design and it will never work. Same thing if you try to ping the inside interface from a host in the DMZ, or from inside to the outside interface etc. The concept will still remain the same, you can't ping an interface of the firewall coming from an opposite interface. It's been my experience that this is something only on Cisco firewalls and I never saw it on any other vendors firewalls or even Cisco switches or routers.
Suhrob Samiev
Thanks Aref for your answer but
from the network 192.168.10.x I can reach Cisco Interface 192.168.50.2(dmz) therefore I have a static route in Cisco FTD to reach 192.168.10.x network via 192.168.50.1 (mikrotik gateway).
You're welcome. That is a different use case and I would expect it to work. The reason why that works is because the traffic flow comes from behind the DMZ interface of the firewall, not from an opposite interface. This is how the topology would look like:
Host (192.168.10.x) <-> Mikrotik Gateway (192.168.50.1) <-> FTD (192.168.50.2)
So from the firewall perspective, it will receive the traffic coming from the host 192.168.10.x via Mikrotik in inbound direction to its DMZ interface, not from another interface. This is expected to work and this is exactly the same as if you try to ping the firewall inside interface from a host in the inside network, same as if you try to ping the outside interface from a host on the internet, obviously assuming ping is allowed on the firewall. However, if you were to try to reach the firewall inside or outside interface from the host 192.168.10.x it won't work for the reasons I mentioned in my previous post.
