FMC 6.7 and vmware tools problem
bodnar.p
Visitor
hello
After upgradit fmc 6.3 to 6.7, cannot start vmware tools. On system/configuration/VMware tools, after trying enable VMware tools, i got Error - Failed to enable VMware Tools. ESXi is supported version 6.7
so i tried to log-in into cli, and when trying to get tools status i got those errors:
root@vmfmc:/etc/vmware-tools/init# ./vmware-tools-services
./vmware-tools-services: line 17: /usr/lib/vmware-tools/moduleScripts/services/vmware-db.pl: No such file or directory
./vmware-tools-services: line 40: /usr/lib/vmware-tools/moduleScripts/services/vmware-db.pl: No such file or directory
./vmware-tools-services: line 41: /usr/lib/vmware-tools/moduleScripts/services/vmware-db.pl: No such file or directory
Usage: vmware-tools-services {start|stop|status|restart|force-reload}
so i checked /usr/lib (and just to be sure also /usr/lib64) and can't find directory vmware-tools
any ideas?
so i checked
cmonterr
Please open a TAC case so an engineer can help you with the following workaround:
== Workaround to resolve vmware tools issue:
1. From expert, elevate to root user with sudo su and enter your password
root@firepower:/# updatedb
root@firepower:/# locate vmware | grep -vw sf
2. This will help you determine if VMWare has been previously installed. If it was installed you will see one or more of the following:
/etc/vmware-tools
/etc/init/vmware-tools.conf
/etc/ld.so.conf.d/vmware-tools-libraries.conf
/etc/modprobe.d/vmware-tools.conf
/etc/selinux/targeted/modules/active/modules/vmware.pp
/etc/dracut.conf.d/vmware-tools.conf
/usr/bin/vmware-*
/usr/sbin/vmware-*
/usr/share/doc/vmware-*
3. Verify if VMWare tools are currently installed:
root@firepower:/# rpm -qa --last | grep vmware | awk '{print $1}' | xargs rpm -e
4. Next, run the following:
root@firepower:/# rm -rf /usr/lib/vmware-tools
root@firepower:/# rm -rf /etc/vmware-tools
5. And run the previous command again to see if the files are still there:
6. Finally, try to re-enable VMWare tools
10 Replies 10
cmonterr
/etc/vmware-tools
/usr/bin/vmware-*
/usr/sbin/vmware-*
This worked for me also.
This just worked for me in 6.7.0.2. Re-enable VMware Tools in the FMC by going to System>Configuration>VMware Tools.
worked for me also
but the locate seems not working anymore
this command:  rpm -qa --last | grep vmware | awk '{print $1}' | xargs rpm -e
was giving me this: rpm: no packages given for erase
so assume was not installed
run these
then updatedb
and was able to enable the tools from the configuration page
This just worked for me as well under 7.0.1 the /usr/lib/vmware-tools directory did not exist on my system and the locate returned this error locate: Old-format locate database '/var/locatedb' is too short to be valid.
However I was able to enable vmwater-tools now.
Everything else besides these:
is just for verification and not strictly required.
Can confirm this works as a workaround for 7.0.1
This worked for me with 7.0.1 as well.
that works for me
Thx
Yordan
srayancha
Community Member
These steps worked perfectly for me.
bodnar.p
Visitor
Can confirm, it is working
thanks for help
