FPR-2110 HA configuration for Interface monitoring and Software
harmitin
Hi, Do we need to have the same type of interface for FPR-2110 HA Active/Standby configuration to core switches? For example, From FW 1, we have fibre connection to core switch A and from FW 2, we have copper connection to core switch B. will HA work on this design?
I wanted to use FPR-2110 for Internal routing or as a router on stick option. Please suggest which Firewall software I should purchase to full fill this requirement to work with C9300x switches? Firepower threat defense software or ASA software?
23 Replies 23
yes, My mean was sub interfaces or Vlan SVI in firewall.
What you mean by Users here? VPN user or something else?
@harmitin not VPN users, number of users behind the firewall would provide an indication on the number of connections and scale.
User means Number of IP behind the firewall or can u give more hints to me?
@harmitin number of IP addresses behind the firewall making connections through the firewall, which provides information into the requirements when scaling the firewall.
Which Value in datasheet I should look to compare with the user requirement?
NO you can not must same interface Number
if you use SFP in FW1 then you must use SFP in FW2
and ALSO same INTERFACE NUMBER
