FPR3130 multi-instance and chassis SNMP
I've read the documentation on how to enable SNMP for the chassis as opposed to each instance and it looks incredibly simple.  I've told it to use the SNMP settings for one of the instances.  On our NMS platform I have discovered all the instances OK, but I was expecting to see additional SNMP data regarding the chassis on the instance that the chassis is configured to use; however, I see nothing else.
Is there something I am missing?
Marcus Eickhoff
I do have the same experience. As I like to retrieve Temperature data by SNMP like on the FP1K and FP2K series, I like retrieving same by the FP3K units. By the way, polling an instance returns no Temperature, and it's making no sense cause the hardware will be managed from the chassis level. I still got no output when doing a walk by SNMP or polling with specific OIDs. Current running version on chassis level is 7.4
Marcus Eickhoff
When verifying on chassis level I do get the following output
The policy was assigned by configuration from FMC using instance settings as it seems, but no community ...
